- Thank you received: 106
Base Gasket - Case to Bottom Of Cylinder
- 4TheKZ1000
- Visitor
I just broke down my engine. I now need to remove the friggen welded gasket off the upper case half, and you know how that goes.
Question ******* Can I use a cooper gasket when I re- install the cylinder to the upper case?
Also, can I use a copper gasket at the upper cylinder to lower head ?
Thanks. Spencer
- turboking
I like copper base gaskets to set deck height available in .005 .010 .020.... :blink:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
- les holt
- Thank you received: 288
Les
- Harvey1327
- Thank you received: 9
I had both copper head and base gaskets but couldn't stop the weeping out of the front of the cam chain tunnel. Tried all the tricks in sealing it but no go. :S So I replaced it with the stock carbon gasket that comes with the wiseco 1327 kit. And also added a breather on top of the cam cover. one out of the oil filler and an extra one from the breather canister all into a double choc chip icecream container.
Like Sellys, no more leaks :laugh:
It took a lot of different types of icecream containers to find the right one. :woohoo: :woohoo:
The old copper head gasket hangs off a nail on the wall and is now a home to a spider who catches flies for a living. :laugh: :laugh:
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
Akron rims,Martin Swingarm
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
shotgun shock,corbin
seat,fat bars,some bling.
www.kzrider.com/media/kunena/attachments/8119/IMG_0461.JPG
- 4TheKZ1000
- Visitor
I will just use a wiseco gasket.
Any secrets to removing the gasket material without the case paint......lol
- bountyhunter
- Thank you received: 337
single edged razor blade and a couple of hours of scraping was what mine took.4TheKZ1000 wrote: Any secrets to removing the gasket material without the case paint......lol
- KZJOE900
- Admin
I used a film of water proof grease (based on other people's experience here who say it makes it easy to take off when you go in again) on my base gasket and went try with the top Cyl/head gasket. I think I read where others have used copper spray to facilitate ease of removal down the road. This for the non-copper gaskets of course.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- sbc1320
- Thank you received: 38
Yeap teaches you some patience for sure.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- 4TheKZ1000
- Visitor
