Compression question PEASE HELP: KZ1000 E 1980
- Flatblackobsession
Re: Compression question PEASE HELP: KZ1000 E 1980
09 Jan 2014 11:05
I appreciate that. I think this sounds like a good approach-- get in there and improve valve function, then start collecting parts/tools for the day the top end gets torn down and rebuilt.
- ZERO
09 Jan 2014 14:04
Obsession. What is your location? I for one wouldn't mind helping you out.
Only Kawasakis have a soul 1977 Kawi KZ1000 special 2000 Kawi ZRX1100
09 Jan 2014 14:24 - 09 Jan 2014 14:25Flatblackobsession wrote: Nesim,
Thanks very much-- I really appreciate the thoughts.
........I keep wondering if the uniform 20 psi increase across all cylinders wouldn't just be cause by the fact that there is oil in the cylinder (like displacement caused by the oil itself). ........
I've often wondered about that myself. Given the fact that at TDC there is very little volume above the piston it seems that adding any oil, for example -let's say a tablespoon, would naturally decrease the volume of air and result in a higher compression reading. Kind of like the effect of a piston with a higher dome. It seems that even in a perfect engine this would happen. Ed
Last edit: 09 Jan 2014 14:25 by 650ed.
09 Jan 2014 14:24
I'm in southeast Arizona, I'd be happy to have some more experienced help on this.
09 Jan 2014 14:31
No eBay APP ID and/or Cert ID defined in Kunena configurationAnyone know what tool (if any) I'd need for shim work on this bike (Kz1000e shaft)? Also, what shim sizes might I be looking at with this?
If a tool is needed, is this the animal I'll need:
Anyone ever use one of these before?
09 Jan 2014 14:51
Right-- very baffling. So, the question would then be: how much of a compression increase (i.e. "drastic" compression increase) indicates oil action on the rings, as opposed to displacement? A hell of a mystery.
I also put a little more than a teaspoon in there-- maybe 15-20 milliliters, but it was the same amount in each cylinder, so it makes me wonder if that isn't why there was this uniform psi increase-- regardless of base cylinder readings.
Any and all thoughts on experiences/theories are appreciated. I really want to get to the bottom of this.
Thanks,
Thanks,
09 Jan 2014 15:07Flatblackobsession wrote: Right-- very baffling. So, the question would then be: how much of a compression increase (i.e. "drastic" compression increase) indicates oil action on the rings, as opposed to displacement? A hell of a mystery.
Thanks,
That seems very logical to me. I would think that if all the rings are holding compression well, the same volume of oil added to each cylinder should result in the same increase in compression readings. I would try a leak-down test to see if you can detect compression leaking from the exhaust or intake valves, or if it's leaking past the rings into the crankcase. Ed
09 Jan 2014 19:30
650ed,
Thanks-- a leakdown test seems like a great idea.
- koolaid_kid
09 Jan 2014 19:57
You need to adjust the valves prior to performing a leak down test.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
09 Jan 2014 21:35
Indeed-- all roads seem to lead to valves. Thanks.
- koolaid_kid
09 Jan 2014 23:16
Absolutely. If the clearances are too tight, the valves will not close completely and all readings will be off, performance down, etc.
1983 GPz 750
- ZERO
10 Jan 2014 02:04
These work O.K. in a pinch. However there is a Kawasaki tool that is much more precise. You wont know what shims you'll need until you get yours out. You'll have to = or- according to your readings. Measure your gap. then ad the size to the next, larger shim. If you encounter a shim that it over tight. Install one two sizes smaller and then re check. It's not hard, but you need a selection of shims, a good quality shim tool, a strong stick magnet and a small pointy screwdriver. Even with experience, the K&L type tools will shoot across the room...crack shims...spit out shims...But, if you wont be doing this job often, maybe the low price would make it worth while. I wish I were closer.Flatblackobsession wrote: Anyone know what tool (if any) I'd need for shim work on this bike (Kz1000e shaft)? Also, what shim sizes might I be looking at with this?
