Cams recognition
- zed1015
Re: Cams recognition
04 Jan 2014 14:12 - 04 Jan 2014 14:21
Z1R are same as Z9 etc but they all can vary by around 0.1 of a millimetre due to manufacturing tolerances and wear due to age and mileage.
I have a few STD sets, a set of GPZ UNI and some Norris cycle .407 for the Café racer but nothing spare at the moment.
The Uni ones are going in the 1428 along with the bigger valve Uni head.
If you find some Uni ones you should go to shim under bucket too.
You should Join the Z1 OWNERS GB where my project links are and post a wanted ad.
I know there were a couple of members who had some POPY - Yoshimura cams that may be for sale.
Last edit: 04 Jan 2014 14:21 by zed1015.
- fordtruck
04 Jan 2014 18:54LarsLykkegaad wrote: I got the std cams, but everyone says they gonna steal to much when you run 1075cc + bore..
Thinkig about doing the J or GPZ swap!
but just heard the z1r had a better grind than the std one!?!?
I am running a 1075cc with stock cams and it runs very strong. I had the head ported and clearanced for larger cams, but never got around to getting them. Although I know it would run even better with cams, I'm happy with the way it runs with the stock ones. You could always run your stock ones and if you wanted more, then get bigger cams.
'77 KZ1000-MTC 1075 kit. Stage 1 port
- sbc1320
04 Jan 2014 19:56 - 04 Jan 2014 20:00
I have stock cams in my stock bore 1000, Kerker header, MTC 10.5 pistons and mine runs really good also.
Ran mine up to 8500 rpms(not enough room around here to really air it out) just taking it around my small town the other day. She runs great down low as well. It had plenty left in her.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
Last edit: 04 Jan 2014 20:00 by sbc1320.
- LarsLykkegaad
04 Jan 2014 21:50 - 04 Jan 2014 21:53
Zed1015- Do you know of any places in Europe who Does the Heads
Id might start with the std and then look for some slightly hotter ones latter
Last edit: 04 Jan 2014 21:53 by LarsLykkegaad.
- zed1015
05 Jan 2014 02:45 - 05 Jan 2014 03:00
Last edit: 05 Jan 2014 03:00 by zed1015.
- zed1015
05 Jan 2014 02:59 - 05 Jan 2014 04:00The head needs doing first as it will then flow more cfm per mm of valve lift even with std cams, larger valves will obviously increase this flow.LarsLykkegaad wrote: Zed1015- Do you know of any places in Europe who Does the Heads
You could fit a later 'J' head which already has larger valves and inlet tracts , you will need an APE idler tower conversion but you will lose 2 points off compression due to the larger combustion chamber so that would need addressing.
I do my own heads etc but it takes more time than it should as I haven't got all the specialist equipment a dedicated tuner does.
If I wanted one of my heads done over here i would send it to ROGER UPPERTON ( you may have heard of him ? ) who lives in LEEDS ,ENGLAND ( Around 60 miles from the port of Hull) He is world famous for championship winning tuning work etc .
HERE.... www.uppertonracing.com/index.html
Last edit: 05 Jan 2014 04:00 by zed1015.
- kzz1king
05 Jan 2014 09:19
Keep up this talk and I will have to pull my head and send it somewhere!
Wayne
Wayne
Home built KZ1000 turbo setup
- LarsLykkegaad
05 Jan 2014 11:19 - 05 Jan 2014 20:22zed1015 wrote:The head needs doing first as it will then flow more cfm per mm of valve lift even with std cams, larger valves will obviously increase this flow.LarsLykkegaad wrote: Zed1015- Do you know of any places in Europe who Does the Heads
Have heard the name but not more than that!
Reason why i choose the A model is that in my opinion its one of the most beautiful R4 engines ever made, so dont really want the J head cause its to squared etc etc
But just Youtubed a bit about porting and think ill try to make a light version of that, and if anyone have pictures of how they did or to do, they are more than welcome to post...or give some tips!!!!
Another thing- do you clean out the crank house to minimize the under compression between the cylinders??
Last edit: 05 Jan 2014 20:22 by Patton.
- zed1015
05 Jan 2014 13:02
Unless you are racing and after squeezing every last ounce of power I wouldn't bother with a windage tray etc for the road as you will never see any advantage.
Just fit a few extra breathers where you can to reduce pumping losses and the chance of oil leaks.
