Best oil pump for KZ1000?
- tomsbadkz
03 Jan 2014 17:36
Is there a better model or year of oil pumps for the KZ1000 for my 1327 project?
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
- DFIGPZ
Re: Best oil pump for KZ1000?
03 Jan 2014 19:25your stock oil pump will be fine just make sure to take it apart and make sure its in good condition an oil pan gate would be a good addition.tomsbadkz wrote: Is there a better model or year of oil pumps for the KZ1000 for my 1327 project?
1984 750 Turbo
- zed1015
04 Jan 2014 02:34
All the oil pumps from the Z9 up to the GPZ1100 etc are basically the same pump and all flow the same at the same pressure.
Just check the internals for wear and scoring etc and maybe fit a thinner gasket to tighten up the side clearances.
Obviously a pump from a later year MAY have less wear on it but that all depends what sort of use and abuse that particular bike was subjected too.
There are higher flow performance pumps available which flow around 40% more.
Turbomaxx in Germany make a billet one which needs a deep sump or pan extender to be fitted.
HERE ... www.turbomaxx.de/oelpumpenkit.html
- turboking
04 Jan 2014 05:32
turbomax looks to be great, but $1700.00 U.S. plus ship.........is too rich for me....need to hit the lotto :woohoo: :woohoo: still a neat pump/ pan extension.
I guess that would be cheap if you had a oiling problem and lost a lot of engine and or turbo parts :dry:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- Old Man Rock
04 Jan 2014 06:27
Is this for a street build or race should be the question.....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- tomsbadkz
04 Jan 2014 09:55
ok. thanks. I have the gate, just haven't installed in the pan yet.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
