Will Kerker kz 650 exhaust fit 82 gpz 750r?
  • mtnman
  • mtnman's Avatar Topic Author
01 Jan 2014 19:40
#617019
Just wondering if Kerker Black 4-into-1 Megaphone Exhaust System - 12760650 will fit 1982 gpz 750r?
Some say yes and others say no???
Thanks Mtnman
Mtnman
  • baldy110
  • baldy110's Avatar
Re: Will Kerker kz 650 exhaust fit 82 gpz 750r?
02 Jan 2014 09:01
#617066
Yes it will work with some minor mods. The header pipe will bolt up to the head. The issue is where the megaphone is bolted to the frame. You will have to modify the mounting bracket on the megaphone to get it to bolt up.
The following user(s) said Thank You: mtnman
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
02 Jan 2014 11:04
#617077
baldy110 wrote: Yes it will work with some minor mods. The header pipe will bolt up to the head. The issue is where the megaphone is bolted to the frame. You will have to modify the mounting bracket on the megaphone to get it to bolt up.
+1
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • mtnman
02 Jan 2014 15:34
#617109
Thanks for info..one question..would I have to cut tab off top of muffler about the Kerker logo on the can and reweld to work or do you just make a new bracket off bike to can??
thanks Mtn
Mtnman
  • sbc1320
  • sbc1320's Avatar
02 Jan 2014 15:39 - 02 Jan 2014 15:40
#617110
Most the time you can fab a bolt on bracket to hang it.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
Last edit: 02 Jan 2014 15:40 by sbc1320.
02 Jan 2014 16:26 - 02 Jan 2014 16:28
#617115
Here's an example of a simple bracket used on a KZ900 LTD (that's lasted forever).
Patton wrote:
Good Fortune! :)
Last edit: 02 Jan 2014 16:28 by Patton.
  • mtnman
02 Jan 2014 18:25
#617130
Patton wrote: Here's an example of a simple bracket used on a KZ900 LTD (that's lasted forever).
Patton wrote:
Good Fortune! :)
That's Awesome!! That's what I wanted to see!!!!
Didn't want to start cutting up a new Kerker or my bike!!
Mtnman
