kz police cases good enough?
- tomsbadkz
01 Jan 2014 15:14
I have a mint set of kz1000 cases from a 78C1 police model. They have the extra ribbing across the front like the MK2 cases. I am building my 1327cc 10.5 to 1 KZ1000 with the 83-84 GPZ1100 head worked by Larry Cavanaugh. I am gonna be running a 300 Avon rear tire. I wont be running a slick. Im using a nice welded falicon crank and a MRE backcut trans with billet 2nd gear. Are these cases gonna be ok or should I pursue a set of MK2 cases? appreciate the responses you guys have. thanks.
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
- wireman
Re: kz police cases good enough?
01 Jan 2014 16:35
Im not aware of there being a differance in any of the kz1000 cases strength wise before the mkII motors came around in 79.
But that being said theres plenty of really fast dragbikes out there that have been running the non mkII cases and cranks for years without problems,i wouldnt worry too much myself.
- Powerstroke_fan
01 Jan 2014 16:53
like wireman says there is alot of people running regular cases. But me personally i like to overbuild everything. So i went with mk11 cases. You can tell mk11 cases cuz they will have extra ribbing in the front as well as a extra triangle gusset that runs down right behind the oil fill hole.
1977 KZ 1000 work in progress
- DFIGPZ
01 Jan 2014 17:16 - 01 Jan 2014 17:58
those cases are fine I have built some engines running 8.40s with 900 cases W/O issue the cases you have are late 78 cases with extra ribbing across the front just like MK2 I would not have issue with them in fact I prefer them they still have old style shift mech. in them with I like more so than the MK2 style that and the fact they are lighter weight anything on the street would be fine with early style cases its when you put slicks, lock up clutches and big power thats when cases become a issue.
1984 750 Turbo
Last edit: 01 Jan 2014 17:58 by DFIGPZ.
- tomsbadkz
01 Jan 2014 17:42
when you say big power, you mean turbo, 1428cc, or nitrous?
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
- z1wiz
01 Jan 2014 17:53
The Mark II cases also have a trans cover like the J model cases.
Over 30 years with z1's, Currently down to only one 75, a j model dragbike, and 2 KZ1000 dragbikes.
- DFIGPZ
01 Jan 2014 18:02put it this way I seen Dwight Seldon on his Turbo charged Kawasaki Pro Mod make a pass at Acto NJ 7.30s .99 sixty foot yes .99 is correct with 900 cases and STOCK UNMODIFIED CLUTCH HUB ! cases are stronger than you think.tom mease wrote: when you say big power, you mean turbo, 1428cc, or nitrous?
1984 750 Turbo
- tomsbadkz
01 Jan 2014 18:10
I don't think that I will be that quick. thanks, I use the cases I have. only want to do this once and do it right.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
- 4TheKZ1000
01 Jan 2014 20:25Please Log in or Create an account to join the conversation.
- tomsbadkz
02 Jan 2014 01:23
holy crap!!!!!! now that's some cases!!!!!!
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
- 4TheKZ1000
02 Jan 2014 12:13
I felt the same Tom
someone on here posted that website and I said the same thing. WTF some awesome stuff.
I think for about $50,000 you could have a running engine from these guys........ :ohmy:
- tomsbadkz
02 Jan 2014 13:55
I viewed it like it was billet porn!!!!! sweeeet....
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
