Clutch Assembly Missing Top Pressure Plate ???????
  • 4TheKZ1000
  • 4TheKZ1000's Avatar Topic Author
31 Dec 2013 18:19 - 31 Dec 2013 18:20
#616904
No eBay APP ID and/or Cert ID defined in Kunena configurationI believe this is missing the pressure plate. What is the deal?
I have seen several others and they had pressure plate.
Am I incorrect ?
Anyone have a pic of the complete setup.
Last edit: 31 Dec 2013 18:20 by 4TheKZ1000.
  • DFIGPZ
  • DFIGPZ's Avatar
Re: Clutch Assembly Missing Top Pressure Plate ???????
01 Jan 2014 18:07
#617008
4TheKZ1000 wrote: I believe this is missing the pressure plate. What is the deal?
Am I incorrect ?
Pardon me but what in the world would you need with something like that if you do not mind me asking ?
1984 750 Turbo
  • 4TheKZ1000
01 Jan 2014 18:27
#617012
I don't want it,
I just tried to inform this seller that the clutch was incomplete, missing the pressure plate .
He is adamant that it is complete.
I have seen them in the past, but couldn't find an example to show him.
Its a bunch of nothing......... :whistle:
  • zed1015
  • zed1015's Avatar
02 Jan 2014 03:26 - 02 Jan 2014 03:34
#617036
It is a HD spring holder machined from billet.
I have a couple of these.
Does need a modified pressure plate to work though but no big deal to modify your own.
[IMG
[IMG
Last edit: 02 Jan 2014 03:34 by zed1015.
  • 4TheKZ1000
02 Jan 2014 07:04 - 02 Jan 2014 07:34
#617051
Hey ZED, do you know who made these?
Have you used one and what did you think about it?
I knew it was missing pressure plate.
thanks
Last edit: 02 Jan 2014 07:34 by 4TheKZ1000.
  • turboking
  • turboking's Avatar
02 Jan 2014 08:37 - 02 Jan 2014 08:42
#617062
NO , the one you bought was complete :dry: .... it's using WAAAAAY heavier (bigger springs) you have to modify your pressure plate.........eliminating the lever lockup :pinch: not really for street use as your hand will wear out...... :S :S
the nice thing about a lockup is they come with light pull springs and the levers/weights apply pressure :huh:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Last edit: 02 Jan 2014 08:42 by turboking.
  • turboking
02 Jan 2014 08:47
#617064
I've seen them sold complete with a pressure plate but as stated not a big deal ....... :side:
1985 GS 1150E
1983 GS 1100E
  • zed1015
  • zed1015's Avatar
02 Jan 2014 10:46
#617073
4TheKZ1000 wrote: Hey ZED, do you know who made these?
thanks
Don't know who made mine .
They came with the Orient express dragbike.
Both are slightly different though so probably made by different people but they are easy enough to make.
They are a bit of a crude solution for clutch slip and were more common before Lock-ups were invented.
Can't really see any use for one nowadays.
Bloody hard to pull in using the std cable mechanism though and usually only used for the launch.
Could be made to work on the road in a sleeper with a hydraulic conversion but it's tricky getting the ratio right as the softer you go the less travel you get and there's a limit before clutch drag becomes a problem.
