KZ1000 Top End Noise??
  • Drooz
  • Drooz's Avatar Topic Author
29 Dec 2013 19:36
#616672
I've got a noisy top end that sounds like it might be cam chain related. I listen to every other Z1/KZ that I have the chance to, and mine is way noisier than any other I've listened to.
It's a stock engine and was only pulled apart to check it before it went back on the road 5 years ago. There aren't a lot of miles on it, only a total of 30,000 km.
Any ideas or comments? I figure we should pull it apart and see what's going on there. :huh: :cheer:
'77 kz1000 (zx10r) Modified/Street
'81 GPz550 "TrackBike"
'05 zx10r Retro/Mod Sportbike 4 SALE!!
'02 zrx1200r Lightly Modified Street SOLD!!
'74 h2b 750 (FZ600) "Mongrel" 2 Stroke SOLD!!
"Invictus Maneo" - I remain unvanquished.
Kawasaki - Let The Good Times Roll!
Mississauga, Ontario. CANADA
Re: KZ1000 Top End Noise??
29 Dec 2013 19:43 - 29 Dec 2013 19:44
#616674
This may be a dumb question, but have you adjusted the cam chain tensioner using the instructions in the Kawasaki Service Manual? Ed
Last edit: 29 Dec 2013 19:44 by 650ed.
The following user(s) said Thank You: Drooz, wireman
  • Drooz
29 Dec 2013 19:58
#616676
Haha! No... not a dumb question at all!! :cheer:
Ya, I've followed the recommended cam chain adjustment procedure to a tee! :) That was my first thought as well.
30 Dec 2013 03:14 - 30 Dec 2013 03:29
#616698
If not already done, would perform a complete tune-up (new plugs, valve clearances, etc.), and sync the carbs.
Even where everything else is perfect, an out of sync carb can result in significant cam chain noise.
Good Fortune! :)
Last edit: 30 Dec 2013 03:29 by Patton.
  • turboking
  • turboking's Avatar
30 Dec 2013 05:14 - 30 Dec 2013 05:15
#616702
I would pull the tensioner first to see if it's at the end.... :dry: before tearing your engine down :blink: Is the noise constant or worse when you rev and then close throttle? If you neglect to keep the cam chain properly adjusted the front cylinder rubbing block will break from chain slap on deceleration... Possible bad idlers, broken front cylinder rubbing block, bad cam chain adjuster roller , bad/at limit tensioner.. cam chains stretch , roller's , idlers and cam chains do go bad :unsure: Good luck , HTH
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Last edit: 30 Dec 2013 05:15 by turboking.
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
30 Dec 2013 05:36 - 30 Dec 2013 05:38
#616704
Looks like turboking pretty much has it covered. i would guess either needs tuned up or bad or wore rollers or bad worn tensioner.
1977 KZ 1000 work in progress
Last edit: 30 Dec 2013 05:38 by Powerstroke_fan.
  • Drooz
30 Dec 2013 07:14
#616716
Thanks for all the good input guys! I knew you'd come through! :cheer:
The issue is mostly at idle and just off idle. it seems to "clear" as the revs climb.
I never thought about the carb sync possibility! :) I have a set of BS34's ready to replace the tired old VM28's that are currently on there. It could very well be a carb sync issue. :)
Thanks again fellas!! :kiss: I'll get at it and report back in a few weeks!
A very Happy New Year to you all!! B)
  • sbc1320
  • sbc1320's Avatar
30 Dec 2013 07:16
#616717
Yeap carbs out of sync and pods will give you a little more noise.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
  • turboking
30 Dec 2013 07:33
#616719
like others stated , hopefully a carb sync issue :unsure: keep us posted :blink:
1985 GS 1150E
1983 GS 1100E
