77 KZ1000 crank suggestion
- tomsbadkz
27 Dec 2013 15:24
I'm doing a 1327cc KZ motor. It's going to be an occasional show off ride. I have the 83-84 GPZ1100 head that Larry Cavanaugh is going to do up for me with a little oversized intake and exhaust valves, kibblewhite springs and Star titanium retainers. Web Cams 435, MTC 10.5 to 1 pistons. I am also setting it up for 300 tire with jackshaft swingarm. I know a guy with a KZ1000 crank that has the Falicon 16 tooth center and has been welded and thrust bearing installed. The price seems pretty good. Anybody think this is the crank I need?
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
- roy-b-boy-b
Re: 77 KZ1000 crank suggestion
27 Dec 2013 15:27
Ask Larry. He will steer you straight.
- tomsbadkz
27 Dec 2013 15:33
ok. will do. I haven't talked to him for a while.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
- Powerstroke_fan
27 Dec 2013 16:50
you will want a good crank that has been welded and if you can afford it, balanced also. I personally went with a mk11 crank. There the strongest cranks. But i would talk to larry. Iam sure he can hook you up.
1977 KZ 1000 work in progress
- 4TheKZ1000
27 Dec 2013 16:58 - 27 Dec 2013 16:59
Falicon quality went way down when they changed ownership a while back. I have heard bad things going on there.
A race prepped MKII crank with all the good stuff done will set you back a $1000.00
If you want a bullet proof engine you better have a quality lower end.
Last edit: 27 Dec 2013 16:59 by 4TheKZ1000.
- DFIGPZ
27 Dec 2013 18:32the crank he is thinking of buying is from Tom Falicon himself when he owned Falicon so there is no issues with it I can assure you of that !4TheKZ1000 wrote: Falicon quality went way down when they changed ownership a while back. I have heard bad things going on there.
1984 750 Turbo
- 4TheKZ1000
27 Dec 2013 19:35 - 27 Dec 2013 19:40_____________________________________________________________________DFIGPZ wrote:the crank he is thinking of buying is from Tom Falicon himself when he owned Falicon so there is no issues with it I can assure you of that !4TheKZ1000 wrote: Falicon quality went way down when they changed ownership a while back. I have heard bad things going on there.
DFIGPZ wrote:
I have meet Tom and his work was very good, I would have no problem buying items from him or made during his ownership of Falicon.
Last edit: 27 Dec 2013 19:40 by 4TheKZ1000.
- tomsbadkz
28 Dec 2013 02:00
i appreciate the imput guys. The guy that has the crank seems to be very knowiedgable and a no B.S. kind of guy. We talked for a while when I met him and he has been working with these older bike for a long time. With child support and mortgage, this has been a slow project and the $$ doesn't come as easily these days. I'm gonna get that crank from him and try to get this ride movin forward. Again, thanks for the imput. really like this forum.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
The following user(s) said Thank You: roy-b-boy-b
