starter clutch mod????
  • Powerstroke_fan
  • Powerstroke_fan's Avatar Topic Author
20 Dec 2013 17:36
#616047
Well i know summer is a little ways away, but iam gonna start working on the bike to get it ready for spring. i have a head gasket leak to fix a oil pressure light dilema and a speedo issue. The speedo reads 10 to 15 mph less than actual speed. but anyway, My starter clutch is going out from cranking over such a big motor. So i will be rebuilding the starter clutch. I remember reading where some people mention they done a starter clutch mod. What does that it involve? How is it done? Any info would be greatly appreciated. i also am thinking about putting a honda cb900 f starter on it. Ive heard it is the starter to use for the extra cranking power.
1977 KZ 1000 work in progress
  • Topper
  • Topper's Avatar
Re: starter clutch mod????
21 Dec 2013 05:17
#616064
I think the mod most people perform is to remove the starter clutch and go to kick start only.
If you've not rebuilt the starter clutch and like the convenience of electric start, I'd suggest you start with a basic starter clutch rebuild kit.
What's the bike? Usually a starter clutch rebuild is just a few springs, end caps and rollers.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • martin_csr
  • martin_csr's Avatar
21 Dec 2013 05:59 - 21 Dec 2013 06:05
#616065
I don't know about a starter clutch mod, but there has been mention of using a starter motor from a Honda.
WGCarbs.com - Vintage bike Forum - Using a stronger Honda starter motor in a Kawasaki
note: the KZR link in the topic doesn't work, but I think this is it 82 1000 starter
Last edit: 21 Dec 2013 06:05 by martin_csr.
  • Powerstroke_fan
21 Dec 2013 07:23
#616067
The bike is a 80 kz1000 1327 motor. More details are in my sig. But i will be rebuilding it with stock parts. I just heard larry c talking about a starter clutch mod and wasnt sure what it consisted of. if it was something good, i would do that instead of stock rebuild with a honda starter as martin_csr and i mentioned earlier.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
21 Dec 2013 08:36 - 21 Dec 2013 08:37
#616070
I couldn't find anything on it???? never heard of it.......does Les or Sanders know? Larry has a forum page, you could drop a thread.
Last edit: 21 Dec 2013 08:37 by 4TheKZ1000.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
23 Dec 2013 06:25 - 23 Dec 2013 06:26
#616199
martin_csr wrote: I don't know about a starter clutch mod, but there has been mention of using a starter motor from a Honda.
I wonder if a stronger starter motor would overcome a weak starter clutch? I rebuilt my starter clutch about 4 yrs ago but it is acting up again. Might be worth a try...
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Last edit: 23 Dec 2013 06:26 by ThatGPzGuy. Reason: sp
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
23 Dec 2013 07:01
#616204
I've repaired two starter clutches. Each of them had at least one mangled spring cup that rendered that spring ineffective. Adding more power would only lead to more slipping.
IMO
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • zed1015
  • zed1015's Avatar
23 Dec 2013 07:31 - 23 Dec 2013 07:40
#616207
No such thing as a starter clutch mod.
All you can do is make sure the rollers etc are in good condition and that the hub they run on is not worn.
Use a J/GPZ 4 brush starter motor if you are still on the old z9/1000 2 brush and it's not man enough to spin your big block.
The Honda cb9/1100 8kw motor is the one to have as a last resort but make sure you get the right one as some are only 7kw.
Last edit: 23 Dec 2013 07:40 by zed1015.
  • Topper
  • Topper's Avatar
23 Dec 2013 07:36
#616209
KZCSI wrote: I've repaired two starter clutches. Each of them had at least one mangled spring cup that rendered that spring ineffective. Adding more power would only lead to more slipping.
IMO
Bill
Bill, by spring cup do you mean the little end caps that go on the spring and pushes against the roller? Or the hole in the housing that the spring sits in?
1979 KZ750 Twin
The following user(s) said Thank You: StreetfighterKz
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
23 Dec 2013 10:02
#616223
IMO
Bill
Hi Topper,
Each spring pushes a cup or end cap against the roller. It's these end caps/cups that I've seen damaged. It's as if they were crushed sideways. I wonder if a longer cup would resist the side load better?
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • Harvey1327
  • Harvey1327's Avatar
23 Dec 2013 15:25
#616253
I replaced my stock starter with a gpz 4 brush starter on my 1327. I found that the old starter was slowly dying without noticing it. Also check the rotor has no play as this was also causing the woodruff key to shear off. I believe the dying stock starter had a bit part in the woodruff key problem.
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
Akron rims,Martin Swingarm
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
shotgun shock,corbin
seat,fat bars,some bling.
www.kzrider.com/media/kunena/attachments/8119/IMG_0461.JPG
  • Powerstroke_fan
23 Dec 2013 15:45
#616256
the mk11 dont have woodruff keys.
Read crh's post #604113
www.kzrider.com/forum/2-engine/590753-ra...engine-size?start=20
Thats what iam talking about.
