Non SR exhaust on a KZ650-SR
  • murquiza
  • murquiza's Avatar Topic Author
20 Dec 2013 09:37
#615997
I have a KX650-SR, it came with a Kerker exahust and pod air filters. I will take it back to factory specs and I will need to replace the exhaust with an OEM one and I'd like to know if the crossover headers have any real effect on the bike or the straight ones will do just fine.
I read that the timing was changed and thus the headers were crossed, finding a cross over exhaust in good shape/price is not easy.
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
  • RonKZ650
  • RonKZ650's Avatar
Re: Non SR exhaust on a KZ650-SR
20 Dec 2013 12:59
#616016
As far as I know the crossover was just for the looks. I think if I remember right the SR was actually a couple HP down vs the standard 650 due to that exhaust system, so any KZ650 exhaust you can fit will work at least as well as the original crossover one. Of course a stock KZ650B or C system is pretty valuable if in good shape and will not look original on a SR and probably require fabrication to mount to some extent.
  • murquiza
20 Dec 2013 13:07
#616018
So it will not be a bolt on replacement from a A B or C to a D? I thought that the only difference would be the headers.
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
  • RonKZ650
  • RonKZ650's Avatar
20 Dec 2013 14:32
#616028
I went out and looked over the 2 systems side by side. It does look like either exhaust would work, but the mounting brackets are totally different, so if you get the KZ650B or C pipes you will need the hanger brackets that go with them to mount to a SR. Also of course if you get the SR exhaust you need the SR brackets. No way to combine parts. Also the B system is 4" longer in the back, so you will look different by 4" than using the original pipe.
The following user(s) said Thank You: murquiza
  • murquiza
20 Dec 2013 16:20
#616032
RonKZ650 wrote: I went out and looked over the 2 systems side by side. It does look like either exhaust would work,.
Thank you! Your help is greatly appreciated. I will have to hunt an SR one then.
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
