- Thank you received: 5
Won't go into 2nd sitting, not running 84GPZ????
- HAFROD
17 Dec 2013 17:56 #615761
by HAFROD
Two 1983 GPz 305's, 1984 GPz550, 1980 KZ550A, 1978 KZ1000A2A
Won't go into 2nd sitting, not running 84GPZ???? was created by HAFROD
I picked up a 78 KZ1000 and a 84 GPZ550 today. They are projects. The GPZ has been sitting since 1988 in a garage. I pulled the plugs and shot a little WD40 in the cylinders. After it sat for about 30 minutes, I put it in 1st gear and rocked it back and forth. The engine is free. I need to remove carbs and clean them and change the oil, filter, plugs and gas out. My question is, it won't go into 2nd gear. Does the bike have to be running or moving before it will go into 2nd gear or is the trans toast? Sorry if its a stupid question. I bought it for $250 and the owner told me it used to run. I'm sure it did run when it was new :laugh:
- loudhvx
- Thank you received: 1616
17 Dec 2013 18:04 #615763
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Won't go into 2nd sitting, not running 84GPZ????
It's called a neutral finder. It only shifts from 1st to 2nd if it's moving above a certain speed.
Usually you can trick it into shifting to 2nd by rocking the bike back and forth, pulling and releasing the clutch in 1st. Eventually it will go into 2nd, but you have to get the knack. From there, you can shift into all of the upper gears.
1981 KZ550 D1 gpz.
Other links.
- Z1Driver
- love the smell of triple smoke
- Thank you received: 55
17 Dec 2013 19:28 - 17 Dec 2013 19:30 #615770
by Z1Driver
Blue 1975 Z1B
Red 2009 Concours 14
Replied by Z1Driver on topic Won't go into 2nd sitting, not running 84GPZ????
^^^^^^^^ I agree. Kawasaki's won't go into 2nd when it's not moving. Fire up the motor, get underway and I bet your problem goes away.
Blue 1975 Z1B
Last edit: 17 Dec 2013 19:30 by Z1Driver.
- geohaydook1
17 Dec 2013 20:35 #615776
by geohaydook1
1980 KZ750e
1981 KZ650 csr (fate undecided)
Replied by geohaydook1 on topic Won't go into 2nd sitting, not running 84GPZ????
The neutral finder is there to keep you from shifting into 2nd while at a stop. Doing so can be downright embarassing..or so I am told :whistle: :whistle:
1980 KZ750e
