GPZ head?
  • TerryK
  • TerryK's Avatar Topic Author
GPZ head?
13 Dec 2013 09:22 - 13 Dec 2013 09:27
#615446
Hey guys, I have a shot at an 82' GPZ1100 engine for cheap and I'm thinking about using the head on my KZ1000. I know the swap is doable but what year GPZ is the best for this swap? I think the 81/82 GPZ head is the same as the "J" model no?
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Last edit: 13 Dec 2013 09:27 by TerryK.
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
Re: GPZ head?
13 Dec 2013 09:45
#615448
My wife has the '81 gpz and it's a FI bike. At the very least, you'll have to plug off the injector ports.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: GPZ head?
13 Dec 2013 10:01
#615453
Agreed...the '81 had the injectors mounted directly to the head, above the manifold with the throttle bodies. The '82 head had the injectors mounted on the throttle bodies, which then mounted to manifold. The '81 head can have the injector ports blocked off, while you don't have to worry about that with the '82 head. And yes, my understanding is that the early GPz heads were similar to the J model heads.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • DFIGPZ
  • DFIGPZ's Avatar
Re: GPZ head?
13 Dec 2013 16:26
#615477
81/82 GPZ heads the same port wise as J head now 83/84 GPZ head a whole different story.
1984 750 Turbo
  • zed1015
  • zed1015's Avatar
Re: GPZ head?
13 Dec 2013 16:58 - 13 Dec 2013 16:59
#615478
1000J or early twin shock gpz 11 is a good straight swap upgrade regardless of having to block off injector ports(depending on model) as the valve angles are the same as earlier kz's.
Later Unitrack factory ported heads are the ones for serious power if you are going bigger CC;s but more work is required in the piston crown department due to the steeper valve angles.
Any of the earlier heads will be a good no hassle upgrade, just remember to compensate for the 2 points of compression drop.
Last edit: 13 Dec 2013 16:59 by zed1015.
  • TerryK
Re: GPZ head?
15 Dec 2013 06:49
#615552
Thanks guys. I guess I pretty much answered my own question. lol As I already have a J head on the bike, its the 83-84 GPZ head I need, but those are like hens teeth these days lol.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
