KZ400 Stock F/R Sprocket Size / Proper Pod Size
- handtius
I'm back for more help, and yes, I'm asking for both in one to minimize the posts. First, I can't do much test riding cause its 30+ ºF in NYC, so this is for winter working that I won't be able to test much until I have a warm weekend.
So, on with it:
1.
My bike seems to have a low top speed for the bike, Usually max out at 70 with the bike screaming at top rpms (i have no tach, just speedo). I'm curious what the stock front and rear sprocket sizes are and if anyone has messed with putting a bigger front, smaller rear on a bike to get a better top speed. I don't need a ton of speed, living in NYC, but I'd like to be comfortable cruising around 65-75 and not feel like the bike is about to explode.
2.
I want to dump my airbox. It's just too clunky and the replacement filters are way too much $$$. What size pods fits the bike? I've heard conflicting info 48mm, 52mm...Just want to make sure I get the right set.
Thanks for the help!
-Ryan
Love me some bikes:
1976 Kawasaki KZ400D
1981 BMW R100CS
- Thank you received: 2829
Attachment 00003_2013-12-10.jpg not found
Attachment 00005_2013-12-10.jpg not found
- handtius
Love me some bikes:
1981 BMW R100CS
www.gearingcommander.com/
home.online.no/~ivbekkel/Workshop%20manual/1974-1977%20Kawasaki
www.kz400.com
- treitz
I am curious as to what the best combo would be for slightly higher top speed as well. I have the same issue with my 79 KZ400. Even though mine is a 6 speed I still feel like it's screaming at 65-70 mph. Like you, I also don't have a tach, so maybe it's not as bad off as I think. Wouldn't mind bumping it a little with a new sprocket on the front or back.
1979 KZ400 - 2-1 Manifold - Mikuni VM34
- Thank you received: 2098
handtius wrote: , , , seems to have a low top speed . . . Usually max out at 70 with the bike screaming at top rpms (i have no tach, just speedo). . . I'd like to be comfortable cruising around 65-75 and not feel like the bike is about to explode. . . .
With stock gearing 15/45 sprockets, attainable top speed should exceed 70 mph.
Taller overall gearing with larger front sprocket and/or smaller rear sprocket would be expected to produce a more relaxed cruising speed with less rpm at any given road speed, would also reduce acceleration, and likely not result in higher fuel mileage.
- handtius
I've been trying out gearing commander. The issue is, they don't have the bike on the list. I've put in the numbers that I understand, but I'm not sure if there's some info I'm missing to properly calculate. What I've deduced is that I should got +3 front / -1 rear. Not sure yet, but that's where I am,
Love me some bikes:
1981 BMW R100CS
- handtius
Love me some bikes:
1981 BMW R100CS
- handtius
Love me some bikes:
1981 BMW R100CS
- Nebr_Rex
- Thank you received: 300
First gear becomes sluggish the taller the gearing gets. First and top gears in both the
early 400 5 speed and the late 400/440 6 speed are virtually identical. Top speed will be
over 90 m.p.h. between 8-9k r.p.m..
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
handtius wrote: . . . I know the top speed on the bike is closer to 90, so I know I'm loosing power somewhere. I think at 70, I should be somewhere in the 3500 rpm range and i can tell it's not there.bike doesn't want to do more then 70-75, maxed out. . . What I've deduced is that I should got +3 front / -1 rear. Not sure yet, but that's where I am,
To confirm, the small "front" sprocket is also known as the "countershaft" sprocket.
The large "rear" sprocket is also known as the "rear wheel" sprocket.
Changing the number of teeth on either sprocket will result in different overall gearing.
Adding or subtracting a tooth from the front (countershaft) sprocket effects a significantly greater difference in overall gearing than does adding or subtracting a tooth from the rear (rear wheel) sprocket.
An 18 tooth front sprocket -- +3 to the stock 15 tooth -- if it will even fit into the space provided, would be expected to produce an enormous (impractical) increase in overall gearing.
Perhaps so high that the bike's normal engine power would be unable to push the bike past 70 mph regardless of whatever the rpm happened to be at maximum achievable road speed.
Large Kaw fours are typically in the 4000 rpm range at road speeds of 60-65 mph with stock gearing that permits roughly touching red line at maximum achievable road speed.
Would suspect that the stock KZ450 would normally pull considerably more than 4000 rpm at 60-65 mph.
