KZ750f Need help on engine case swap
- usmc1316
06 Dec 2013 18:04
I have a 83 KZ750f (Shaft). When I got it the case was cracked and chipped around the (pulsing coil). The previous owner dropped it on that side.
So.... this is my question. Can I use the engine case off an KZ650? KZ750?
- koolaid_kid
Re: KZ750f Need help on engine case swap
06 Dec 2013 18:06
Just to clarify terminology:
The engine case is the two halves that house the crankshaft and transmission.
The clutch cover is what houses the clutch and signal generator for the ignitor.
Are you speaking of the clutch cover?
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- usmc1316
06 Dec 2013 18:08
I need the whole case, the wall is cracked and small part is broken off.
- usmc1316
06 Dec 2013 18:13Attachment unnamed.jpg not found
This is what I am talking about
- JR
07 Dec 2013 08:30 - 07 Dec 2013 08:34
Sorry I can't say if cases from a chain drive 750 would work but I thought cases came as a matched pair and had to be changed together ...... which would mean a huge amount of work for the issue you have.
If it were me I would use JB Weld. I would put a piece for a tin can with some greaseproof paper on the inside an put JB Weld on the outside. Let it set. Sand and paint if necessary. Remove tin and greaseproof paper.
From the photo it looks like a small chip. I cant see the oil pressure sensor but am thinking it it is hidden behind the pulse coil plate and not near the break.
Last edit: 07 Dec 2013 08:34 by JR.
- Nebr_Rex
07 Dec 2013 09:13usmc1316 wrote:Attachment unnamed.jpg not found
Need a pic of the outside where it is cracked. It may be repairable.
And yes, the cases are machined as a pair. I believe interchangeable with
the late 650/750 chain drive also.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- usmc1316
07 Dec 2013 19:06
I took a chance and bought a KZ650 motor for 50.00 off of craiglist.
If it doesn't work ill do the repair on the original.
