Oil cooler install.
- yeekim
Oil cooler install.
03 Dec 2013 00:20 - 03 Dec 2013 04:59
Hi!
Thinking of installing the oil cooler to my not so "cool" KZ 750 H3.
Have an oil pan with "pipes" and cooler.
Any con's?
greetings
Any con's?
greetings
Ex nihilo nihil fit!
Last edit: 03 Dec 2013 04:59 by yeekim. Reason: More info
- Bozo
- Ride it like u stole it
Re: Oil cooler install.
03 Dec 2013 04:11 - 03 Dec 2013 04:15
I don't see what you want to do, being a two stroke there is no oil pump in the gearbox (its oil bathed). The cylinders are cooled by air, 2-stroke oil, and petrol mixture., so cooling the gearbox oil is a waste of time. You could run colder plugs but they can be a pig around town.
I used to own Mach3's and tried everything, even the air scoop from the GT550 suzuki. Enjoy it as it is, try not to idle in one spot too long (don't warm the engine up for more then a minute), Boy this brings back old memories, I dropped my Z1R dragging a 750 Mach4 (1979) at 140kph I hit a bump on the road and flipped my bike (I saw the speedo before I came off)
Last edit: 03 Dec 2013 04:15 by Bozo. Reason: added extra meaning
- StreetfighterKz
03 Dec 2013 04:16Bozo wrote: being a two stroke
I believe he's referring to a Kz750H3 (LTD).
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Bozo
03 Dec 2013 04:30
opps, there is a 750 Mach4 H3, very confusing??, initially I thought I made a mistake so I checked on the web to see what Happens using "750 H3" and it showed the triple.
Oh, well back to the naughty corner for an hour or two.
03 Dec 2013 04:35 - 03 Dec 2013 22:09yeekim wrote: . . . 750 H3 . . . .
Including information about year of manufacture is also helpful to viewers,
such as 1982 KZ750-H3.
It's easy to put full information about a bike in your signature where it shows in all posted messages, past and future.
And the signature may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do.
Here's how:
Last edit: 03 Dec 2013 22:09 by Patton.
- koolaid_kid
03 Dec 2013 16:03No true cons to mention. You will have to figure out how to mount it to the frame. Be sure and use rubber isolators.yeekim wrote: Hi!
Any con's?
greetings
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
The following user(s) said Thank You: yeekim
