Possible oil leak past galley perimeter o-ring...
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
02 Dec 2013 23:26 - 02 Dec 2013 23:27
#614681
What likelihood of oil passing the o-ring between my head gaskets? I'm noticing a little oil resting on the lower four cylinder block cooling fins, and initially thought maybe the chain tension-er was seeping oil, but...? :S
1982 KZ1100-A2
Last edit: 02 Dec 2013 23:27 by daveo.
Re: Possible oil leak past galley perimeter o-ring...
03 Dec 2013 04:28
#614688
If not already done ---
Would thoroughly clean the engine, allow it to completely dry, spray foot powder onto suspected leak areas (all over edges of the cam cover and head gaskets, around the tach drive and exhaust clamps, etc.).
Should then look like a clean white blanket of freshly fallen snow.
Start the engine, and watch for appearance of darkening area where the oil is coming through the powder.
The source of leak is usually very evident.
Good Fortune! :)
  • Garn
  • Garn's Avatar
03 Dec 2013 16:39 - 03 Dec 2013 16:42
#614717
Daveo, do as Patton recommends and you should be able to determine where the leak is coming from.
Tacho drive is very common. I have seen the centre perimeter o-ring leak. The trouble was, that the two head gaskets I used were about 1/2 mm ( or more) thicker than the standard size. when I looked at them, I thought they looked great, however they did not crush enough, hence not putting enough compression on the O-ring
To aggravate the above situation further, the O-ring may have been an el-cheapo and was under size in thickness.
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Last edit: 03 Dec 2013 16:42 by Garn. Reason: adding info!
  • daveo
  • Premium Member
  • Premium Member
03 Dec 2013 20:47 - 05 Dec 2013 21:29
#614729
Thanks guys... :)
1982 KZ1100-A2
Last edit: 05 Dec 2013 21:29 by daveo. Reason: minimize text
  • daveo
  • Premium Member
  • Premium Member
19 Dec 2013 21:47 - 20 Dec 2013 07:25
#615958
Nope, that wasn't it...halleluiah! :whistle: Nor was it a fuel drip off the head flange at the #2 intake manifold...
It was the O-Ring between the Ape tensioner and the cylinder block.
When i pulled that tensioner off, there it was...the hardest O-Ring on the face of the earth, which cracked when flexed just a little.
I didn't think that could possibly have been the issue, but I'm soooo glad that it was.
Now that is over, and I can pack the bike up for a couple months, and forget about it. That won't work. :laugh:
1982 KZ1100-A2
Last edit: 20 Dec 2013 07:25 by daveo. Reason: minimize paragraph
