GPZ 750 turbo head/cams
- JeepCJ
23 Nov 2013 14:44
I have been looking around for an 83-85 GPZ 750 head and cams to bolt onto my Zeph750. Is there is difference in the GPZ turbo cams, and head, compared to the GPZ 750?
Bob
Bob
- Dr. Gamma
Re: GPZ 750 turbo head/cams
23 Nov 2013 14:54
Don't know about the head, but the cams in the 750 Turbo (ZX750E) are stock KZ650 cams!!!
1986 RG500G 2 stroke terror.
- DFIGPZ
23 Nov 2013 15:42Yes, GPZ 750 has a hotter cam and better flowing cylinder head than the turbo.JeepCJ wrote: I have been looking around for an 83-85 GPZ 750 head and cams to bolt onto my Zeph750. Is there is difference in the GPZ turbo cams, and head, compared to the GPZ 750?
Bob
1984 750 Turbo
- T_Dub
23 Nov 2013 16:52
Yeah the turbo head is basically useless. The Zephyr one is probably better.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- guitargeek
23 Nov 2013 20:22
You'd probably be better off with the head you have now, and a GPz750 intake cam.
Someday, if I can score a deal on one, I'd like to pick up a ZR7 head, just to get those fresh valve springs.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- kawi810
05 Dec 2013 09:31
what is the difference between the N.A.head and the turbo head when it comes to the ports and combustion chamber on the 84-85 zx750,s?
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
- steell
05 Dec 2013 13:59 - 05 Dec 2013 14:00kawi810 wrote: what is the difference between the N.A.head and the turbo head when it comes to the ports and combustion chamber on the 84-85 zx750,s?
The Turbo head is drilled and tapped for a temp sensor, but I don't know of any differences in the ports or combustion chamber.
Last edit: 05 Dec 2013 14:00 by steell.
- DFIGPZ
05 Dec 2013 16:01Big difference in cyl head from gpz 750 to 750 turbo ports on turbo head are similar to KZ650 ports plus drilled for air temp sensor GPZ 750 heads were hand blended from factory and much better port than turbo head.kawi810 wrote: what is the difference between the N.A.head and the turbo head when it comes to the ports and combustion chamber on the 84-85 zx750,s?
1984 750 Turbo
