Separating engine cases
  • geerbangr
  • geerbangr's Avatar Topic Author
23 Nov 2013 00:47
#613854
Are there locations for running jack bolts in to separate the cases or how do you go about splitting them ?
1978 KZ 1000
I go by Jason
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
Re: Separating engine cases
23 Nov 2013 01:07
#613855
If you're asking questions like this, you really need to get a factory service manual.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
  • geerbangr
23 Nov 2013 01:32
#613856
I have a factory service manual. However I'm out of town working and don't carry my factory manual around with me. I was running some thought through my think tank and wanted to get a question answered. I'll wait to get home and go through my factory manual so I don't disturb anyone else at 0430.
1978 KZ 1000
I go by Jason
  • guitargeek
23 Nov 2013 02:10
#613857
:laugh:
I don't know about the older models, but on the 650/750 and J-model engines there are pry points. Use a great big flat screwdriver and lots of care...
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
23 Nov 2013 03:55
#613858
KZ 1000 s have jack bolt holes
The following user(s) said Thank You: geerbangr
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
23 Nov 2013 04:21 - 23 Nov 2013 04:23
#613859
There in the front of the motor. right in line with the rest of the bolts. They should be the only two that didnt have bolts in them. And on the other side of them there will be a little lip type deal you will see. There are two of them. Just make sure you have all the bolts removed.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Last edit: 23 Nov 2013 04:23 by Powerstroke_fan.
  • floivanus
  • floivanus's Avatar
23 Nov 2013 07:21
#613867
Dont forget the five bolts on the top side around the starter motor
Past; 78 kz1000, 83 kz550
Andrew
23 Nov 2013 07:39
#613868
Good Fortune! :)
  • geerbangr
23 Nov 2013 20:47
#613957
Awesome guys thanks !!
1978 KZ 1000
I go by Jason
  • guitargeek
23 Nov 2013 21:34 - 23 Nov 2013 21:35
#613958
I bet there's a pdf file of that manual somewhere... Back before my phone went tits up, I carried around a copy of my manual in my pocket.
Last edit: 23 Nov 2013 21:35 by guitargeek.
24 Nov 2013 06:35
#613970
Here's a link to download the FSM covering the J model:
"Pry points" are noted.
"Jack bolts" aren't mentioned.
www.kawiworld.com/images/stories/KZ1100man.pdf
Excerpt from page 44:
Z1 - KZ900 models also provide for jack bolts.
Good Fortune! :)
