Tuning pilot adjustments
- MTH76
22 Nov 2013 09:59
Has anyone checked the exhaust temp after adjusting the pilot mixture screws ?
Is there a known optimum exhaust temp that you could adjust to ?
I would think it would be easier to do it this way instead of by ear.
Thanks for any ideas or thoughts.
1976 KZ900 1075 head ported,over-sized intake valves shim under bucket Z-4 cam motion cams 34mm RS carbs back cut trans GS1000 swing arm with 3.5" Sun rim MotoGPwerks stainless steel pipe
- JR
Re: Tuning pilot adjustments
22 Nov 2013 10:10
search here for "colortune" or search the web for Guson Colortune.
Old Man Rock uses one and has posted on it several times. Back in the day when car engines were simpler some of my buddies used to swear by it. Its available from the Morgan Carbtune people.
