1980 KZ 1000 Classic EFI Question
  • Wolfpaak
  • Wolfpaak's Avatar Topic Author
21 Nov 2013 04:57
#613610
I am working my way through the fuel system, cleaning it up after the bike has sat for a number of years. My question is about the fuel return nipple on the tank. The one I have seems to be "stuck". It looks like it should be spring loaded and open and close to help regulate fuel pressure, this is just a guess. Anyone know how this part works?
Thanks for the help!
Kenny
  • Wolfpaak
Re: 1980 KZ 1000 Classic EFI Question
21 Nov 2013 05:00 - 21 Nov 2013 05:05
#613611
Here is a pic of the part in question.
Attachment Pressurereliefvalve003resized.jpg not found
Kenny
Last edit: 21 Nov 2013 05:05 by Wolfpaak. Reason: Adding Picture
  • T_Dub
  • T_Dub's Avatar
21 Nov 2013 11:26
#613646
Its a relief valve according to the parts diagram. Comes after the pressure regulator. I'm going to say it is basically a check valve so that the regulator works properly. Is it really stuck? It probably wont open til 30-40psi or more.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • farmer1
  • farmer1's Avatar
21 Nov 2013 11:29
#613647
It is a one way valve.It does take a bit of pressure to get it to open.The pressure regulator is the canister on the other end of the fuel line that goes to the tank return that you have shown. cheers farmer.
  • Wolfpaak
21 Nov 2013 18:55
#613688
T_Dub wrote: Its a relief valve according to the parts diagram. Comes after the pressure regulator. I'm going to say it is basically a check valve so that the regulator works properly. Is it really stuck? It probably wont open til 30-40psi or more.
When I took it out to check it I blew air in the nipple end from my compressor and not much happened. Very little air came out through the two holes. I soaked it in Marvels Mystery oil for a couple of days and tried it again, same results. I then tried to push it open with a small screw driver didn't budge. So, yes, I think its stuck but didn't know if it had a preset setting or if it was "supposed to" move. Your answers have helped out ALOT! Will try to find a different one,Thanks!
Kenny
  • Wolfpaak
22 Nov 2013 06:38
#613726
DO you think a "straight through" nipple would work if a replacement cant be found?
Thanks again.
Kenny
  • T_Dub
  • T_Dub's Avatar
22 Nov 2013 06:54
#613729
Looks like they're still available. They came on these models as well, so you can widen your search.
KZ1000-G1 (Classic) (1980)
KZ1100-B1 (GPz) (1981)
KZ1100-B2 (GPz) (1982)
ZN1300-A1 (Voyager) (1983)
ZN1300-A2 (Voyager) (1984)
ZN1300-A3 (Voyager) (1985)
ZN1300-A4 (Voyager) (1986)
ZN1300-A5 (Voyager) (1987)
ZN1300-A6 (Voyager) (1988)
ZX1100-A1 (GPz) (1983)
ZX1100-A2 (GPz) (1984)
ZX750-E1 (GPz 750 Turbo) (1984)
ZX750-E2 (GPz 750 Turbo) (1985)
www.partzilla.com/parts/detail/kawasaki/KP-16130-1002.html
www.ronayers.com/VALVE-ASSY-RELIEF-P3496741.aspx
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • sbc1320
  • sbc1320's Avatar
22 Nov 2013 07:27
#613732
Wolfpaak wrote: DO you think a "straight through" nipple would work if a replacement cant be found?
Thanks again.
Kenny
No, it wouldn't build any fuel pressure then.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
The following user(s) said Thank You: Wolfpaak
  • Wolfpaak
22 Nov 2013 11:39
#613747
Thanks again.
Kenny
I didn't think so, but someone offer up a tank with just a straight through nipple
in it.
thanks for all the help.
Kenny
  • farmer1
  • farmer1's Avatar
22 Nov 2013 11:54
#613750
Yes a straight thru would work as it just a one way valve. The pressure regulator is the canister. You should be able to get the valve from REDLINE CYCLES .
  • sbc1320
  • sbc1320's Avatar
22 Nov 2013 11:57
#613751
farmer1 wrote: Yes a straight thru would work as it just a one way valve. The pressure regulator is the canister. You should be able to get the valve from REDLINE CYCLES .
Just seemed like to me if it after the regulator that it wouldn't let it make any pressure if you had a straight nipple there instead of the relief valve.
  • Todd smith
  • Todd smith's Avatar
27 Nov 2013 16:38
#614256
I have not forgot about you, I will be at my buddy's hours this week end, do you think it is to hold pressure in the fuel line so it doesn't have a long crank time for starting , it doesn't look like a fuel regulator if it is it not a very good one . Thanks Todd smith
