1983 KZ1100 Spectre starter problems
- Puffin
Re: 1983 KZ1100 Spectre starter problems
21 Nov 2013 00:16
Check the Earth cable before shelling out your money. A bad earth to the chassis gives the same symptom your describing
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
KZ1100
21 Nov 2013 00:21 - 21 Nov 2013 00:31Hotrod624 wrote: Do you think I should get a rebuild kit for it? I just don't want to drop 140.00 on a starter at the moment. I've seen the rebuild kit for 30.00. I have already had the starter off, just nervous about taking it apart.
What components are included in the "rebuild kit?"
Lots of good info on kawasaki.com, including parts diagrams, part names, part numbers, models sharing same part, availability, etc. Here's a link for help with navigating the site and finding information.
www.kzrider.com/forum/13-bike-related/37...imitstart=0&start=20
Last edit: 21 Nov 2013 00:31 by Patton.
- koolaid_kid
21 Nov 2013 06:02
I have seen the rebuild kits before (I do not remember the site) and they contained the wear parts. Brushes, bearings, bushings, seals, etc. As you would expect, the large parts such as the armature are not included.
Hotrod64, if you could post a link to the kit it would help.
I rebuilt my GPz starter a couple of years ago and it is not that difficult. You just have to be careful, take your time, and be patient. I would do it again in a heartbeat over purchasing another starter.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- Hotrod624
21 Nov 2013 21:19
Here's the link to the starter rebuild kit
www.d2moto.com/p-73677-1982-1983-kawasak...DS97oCFUtp7AodETwArg
- koolaid_kid
22 Nov 2013 13:18
Yup, that looks like it. Seals, o-rings, bushings, bearings, plate containing the brushes/springs, etc.
You will have some left over parts, as those kits are for multiple applications.
The aluminum plate on the top has the ceramic/plastic bit that sticks through the starter casing so the 12V power can bolt onto it.
1983 GPz 750
- Hotrod624
22 Nov 2013 18:28
Well I just got done cleaning the starter, haven't put it in yet. Crossing my fingers!
- Hotrod624
22 Nov 2013 21:02
Well I hooked it up and for some reason the starter didn't even try and it started smoking.
- geerbangr
22 Nov 2013 21:33
Ok you've got the starter reassembled incorrectly. When an electrical component lets the magic smoke out it's typically junk. :S
1978 KZ 1000
I go by Jason
I go by Jason
- Hotrod624
22 Nov 2013 21:49
Its not that hard to reassemble, so it must have been something small that I have over looked. Have any idea's what this could be?
- koolaid_kid
23 Nov 2013 10:02Not necessarily, especially the starter. You have a direct short to ground. On my GPz, the ceramic insulator had broken. That is the first place I would look.geerbangr wrote: Ok you've got the starter reassembled incorrectly. When an electrical component lets the magic smoke out it's typically junk. :S
1983 GPz 750
- Hotrod624
24 Nov 2013 14:17
I have found a known good starter for cheap so I should have it by Friday.
- Hotrod624
13 Dec 2013 17:41
Ok so i have deduced that the problem is a bad ground. I have grounded the starter directly to the negative battery post and it acts almost like its suppose to, Still acts a little weak, but turns over so much better! So my question is where are the ground points on the bike? Its a shaft driven if that makes a difference.
