- Thank you received: 4
KZ 1000 cafe build recommendation needed
- cross
- '05 ZRX1200R
How does this bike compare to the non police bikes from 70's and 80's?
It does look taller, does it have taller forks?
Is it good candidate for cafe build or should i get something from 70's/80's?
I would possibly like to have modern fork and swing arm upgrade as well.
Any suggestion and opininons appreciated.
SK
Sasha K.
Bikes I owned
'02 Vulcan 500ltd
'01 Yamaha V-Star 1100 Classic
'01 BMW R1200C
'01 Honda Valkyrie
'05 Triumph Bonneville America Custom
'05 Kawasaki ZRX1200R
- The_Raven
Having said that, wouldn't a parallel twin KZ be a more appropriate choice? It seems to me that the bikes you're trying to mimic were Triumph and Norton twins.
-Mark P.
Salem, MA
Widowmaker, 1982 KZ1000J2 @1100cc
Red Scare, 1994 Honda VF750C Magna
I intend to die from living.
- Mercury Kid
Please do as much or more to improve it mechanically as you'll likely do to improve the looks. Getting tired of seeing stock bikes with clubmans and a glass seat called "cafe racers". Well where's the "racer" part?
'76 KZ900-Z1 clone
Z1 70's period longbike
- cross
- '05 ZRX1200R
I was thinking of going for something more like a retro style bike with modern forks and swing arm.
Sasha K.
Bikes I owned
'02 Vulcan 500ltd
'01 BMW R1200C
'01 Honda Valkyrie
- cross
- '05 ZRX1200R
Thanks
Sasha
Sasha K.
Bikes I owned
'02 Vulcan 500ltd
'01 BMW R1200C
'01 Honda Valkyrie
- 80B4
- Thank you received: 105
1980B4 1000
1978 Z1R
1978 B3 750
- guitargeek
- Thank you received: 50
Wiseco 1075cc pistons , mill + gasket match + port & polish the head, Keihin FCR carbs, lumpy cams .
Look for a gas tank from an early GPz1100, '81 or '82.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- cross
- '05 ZRX1200R
It is in pretty good condition, runs great, no weird noises, its just a bit more then i would like to spend.
How much maintenance do this these engines need at this mileage? I've read on some vintage bike forum that KZ1000 engines need valve job every 25k miles, is this true?
Sasha K.
Bikes I owned
'02 Vulcan 500ltd
'01 BMW R1200C
'01 Honda Valkyrie
- guitargeek
- cross
- '05 ZRX1200R
Is this true? It seems a bit excessive.
What should I be expecting to do to this engine with this many miles?
Other then oil change and tune up.
Thanks
Sasha K.
Bikes I owned
'02 Vulcan 500ltd
'01 BMW R1200C
'01 Honda Valkyrie
- cross
- '05 ZRX1200R
Since riding season in California starts early, I'm not sure I'll have the time to do a complete build. I would like to ride it until next winter when I'll do complete teardown and get frame painted and upgrade the engine.
Not sure yet what I will do with the body work. Going back and forth between cafe racer or retro looking bike, possibly with cop theme.
I'll see, have to get bike first.
Thanks for the suggestions
Sasha K.
Bikes I owned
'02 Vulcan 500ltd
'01 BMW R1200C
'01 Honda Valkyrie
- guitargeek
Maybe if you use the bike for racing...cross wrote: Valve job as in remove the head, inspect seats and guides, valve laping, etc.
Check valve clearance, make sure you can still get the gap you need with the shims available.What should I be expecting to do to this engine with this many miles?
Thanks
Measure the cam chain for stretch.
Replace the valve guide seals.
Measure ring end gap, measure cylinder dimensions, make sure everything is within spec.
Seriously, KZ engines are anvils.
