- Thank you received: 5
jumping out of 2cd gear
- rlcarter
16 Nov 2013 07:50 #613163
by rlcarter
1980 KZ1000 G w/carbs..
jumping out of 2cd gear was created by rlcarter
1980 kz 1000 G jumps out of 2cd gear i was told it could be bad dogs or bent shifting fork. i split the cases and did not see any obvious problem. i have never done this before. could i be missing something ? any ideas would be helpful and appreciated.
Thanks,
rlcarter
Thanks,
rlcarter
- 4TheKZ1000
- Visitor
16 Nov 2013 07:55 - 16 Nov 2013 10:16 #613165
by 4TheKZ1000
Replied by 4TheKZ1000 on topic jumping out of 2cd gear
2nd gear dogs in tranny are rounded off.
quite possible that you will need to break engine completely down and spilt cases to get at tranny.
Common problem with KZ trans.
Attachment gears_2013-11-16.jpg not found
Last edit: 16 Nov 2013 10:16 by 4TheKZ1000.
- rlcarter
16 Nov 2013 08:01 #613166
by rlcarter
Replied by rlcarter on topic jumping out of 2cd gear
i have already done that did not see an obvious problem should the wear on the dogs be very noticeable .
- racer54
- Thank you received: 114
16 Nov 2013 11:15 #613177
by racer54
Replied by racer54 on topic jumping out of 2cd gear
You would notice any rounding off of the dogs. Check the opposing slots in engaging gear to see of the slots have worn ramps. This is a well-known problem with these trans. 2nd gear is the trouble maker. Be sure the shift lever is postioned so that when you pull up on the lever you have enough leverage to pull it up far enough to get it fully into 2nd gear. I've seen this happen before.
- nickleo373
- Thank you received: 33
16 Nov 2013 12:14 - 16 Nov 2013 12:15 #613179
by nickleo373
1981 KZ550C LTD
"If you ain't first, you're last"
Replied by nickleo373 on topic jumping out of 2cd gear
Make sure you're shifting up hard. A lot of these bikes will drop out of second and into neutral if you dont shift up with enough force
1981 KZ550C LTD
Last edit: 16 Nov 2013 12:15 by nickleo373.
- Garn
- Thank you received: 13
16 Nov 2013 12:57 - 16 Nov 2013 13:24 #613185
by Garn
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Replied by Garn on topic jumping out of 2cd gear
Could be, the dogs/ slots on the gears are only slightly worn, however, the clearance (end-float) on the shaft with the offending gears is too much and allows the gears not to be firmly held together (dogs engaged). There is a spacer on the shaft in question may be left out or need larger one!
Unfortunately it requires a re-split of the crank-cases.
RegardZ.
PS .... Have a look at this, way back 15//1/11
www.kawariders.com.au/showthread.php?153...box-Trouble-z1/page2
RegardZ.
Sydney Australia
Last edit: 16 Nov 2013 13:24 by Garn.
- rlcarter
17 Nov 2013 18:18 #613296
by rlcarter
very helpful info i will take a closer look at everything hopefully find something . you guys are great. another question. does the shifter drum have a history of failure ? thanks again...
rlcarter
rlcarter
- rlcarter
17 Nov 2013 18:27 #613301
by rlcarter
thanks for the info racer54 im gonna check closer and see what i find . still learning . hopefully i will find something
thanks have a great day.
- Garn
17 Nov 2013 22:31 - 17 Nov 2013 22:39 #613320
by Garn
Sydney Australia
There is one item I can think of that has a history of a failure, it is the boss that supports the lever shaft. it is part of the lower case casting... A real curse of a job, because when it is repaired with an alloy weld, it fills the space where a spring fits ( 3coil or later four coil).
Lets hope its not this one. I'm hoping it will be something simple.
.RegardZ.
.RegardZ.
Sydney Australia
Last edit: 17 Nov 2013 22:39 by Garn.
