So close to starting!
  • prizethedoubt
  • prizethedoubt's Avatar Topic Author
15 Nov 2013 13:43
#613125
The bike is so close to starting! Sorry if this is technically not the right spot for this post. Check out the video...
The best result I had is when I blasted starter fluid, with the choke on half way, the bike started immediately, and was idling at 3k RPM on its own. Oil started coming out of the oil pressure gauge, so I turned the bike off and tightened the bolt a bit. Any advice? I don't want to screw up my new starter motor/battery from trying to start the bike too many times in a short period.
Thanks friends!
KZ440 LTD 1982
KZ 440 LTD 1982.
  • Cynjut
  • Cynjut's Avatar
Re: So close to starting!
15 Nov 2013 14:09
#613127
I'd be more concerned about the oil pressure.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
  • 0Z.Z1R Mk2
  • 0Z.Z1R Mk2's Avatar
15 Nov 2013 15:23
#613135
Why no choke?
1976 KH 500 triple
1978 Z1R D1
1980 Z1R MK2
1983 Gpz750 turbo
2007 ZRX 1200r
1982 GSX 1000S Katana
1983 GSX 1000S Katana
Don't knock my turbo lag - it gives your naturally aspirated a chance..
  • Garn
  • Garn's Avatar
15 Nov 2013 22:37
#613145
Has it just had new rings or just been overhauled.
Remove plugs and give it just a little oil. It's need oil to seal the rings.
Should start!
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
