Andrews Cams & Valve train ?
  • DFIGPZ
  • DFIGPZ's Avatar
Re: Andrews Cams & Valve train ?
08 Nov 2013 15:44
#612543
i have done many street bikes with 425in lift cams and shim on top buckets the key is make sure you have a good valve spring in AND CHECK SPRING PRESSURES when setting up head also when I use shim on top buckets I set valve clearance .004in int and ex and keep a close eye on valve adjustments.
1984 750 Turbo
