Alternator cover Gasket Leak.
  • jp-15
  • jp-15's Avatar Topic Author
07 Nov 2013 14:53
#612347
I replaced the gasket on my alternator cover and put a thin layer of the High temp Permatex copper on both sides of the gasket. Is this a no-no? Does this gasket go on dry with no permatex? Thanks.
1976 bobber KZ900
903cc
K&N Pods
4-1 V&H
VM26's
Dynatek S w/Green Coils.
Winter Project= 10.25:1 1015 cc kit w/ Web cams and Refurbished head. 33 smoothies hopefully.
  • sbc1320
  • sbc1320's Avatar
Re: Alternator cover Gasket Leak.
07 Nov 2013 15:25 - 07 Nov 2013 15:29
#612350
Most gaskets can and do go on dry as that is what they do as in seal. Coppercoat, Gasgacinch, etc.. can be used on some as needed. Don't really need to put a bunch of silicone, but if allowed to dry you should be ok. Just don't want a bunch to get inside the engine. Generally a dab of silicone is good to use where you have gaskets crossing over two different mating surfaces. Where this happens just put a litlle below and above in that area only.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
Last edit: 07 Nov 2013 15:29 by sbc1320.
  • jp-15
08 Nov 2013 05:24
#612431
So what procedure do you recommend for this particular gasket? Light spread on both sides of gasket? 1 side? No sealant? Its leaking at the very bottom.
1976 bobber KZ900
903cc
K&N Pods
4-1 V&H
VM26's
08 Nov 2013 05:27
#612432
Dry. Are you sure the leak isn't coming from the point where a wire penetrates the case? Ed
08 Nov 2013 07:23
#612445
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And the signature may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do.
Here's how:
Good Fortune! :)
  • jp-15
08 Nov 2013 08:25
#612460
Thanks Patton. Got that one buttoned up. Unfortunately Ed, I checked and it's definetly not from a penetration in the cover itself. Seems to be coming from around the bottom screw. Will try again Dry. Thanks.
1976 bobber KZ900
903cc
K&N Pods
4-1 V&H
VM26's
08 Nov 2013 08:50
#612467
jp-15 wrote: . . . not from a penetration in the cover itself. Seems to be coming from around the bottom screw. . . .
KZ900 usually has a small amount of oil under the alternator cover.
There's a gasket between the cover and case, and also a supposedly leak-proof rubber grommet where the wires pass through the cover.
The grommet is the more common leak source.
www.z1enterprises.com/ItemDetails.aspx?i...+1100&item=RIGROMMET
Good Fortune! :)
  • jp-15
09 Nov 2013 16:52
#612643
Good info Patton. Thanks. Is this the only fix for that leaking grommet? Would like to resort to cutting and soldering the wires as a last measurement.
Thanks.
1976 bobber KZ900
903cc
K&N Pods
4-1 V&H
VM26's
09 Nov 2013 20:24
#612662
jp-15 wrote: . . . Is this the only fix for that leaking grommet? Would like to resort to cutting and soldering the wires as a last measurement. . . .
This link is to a thread with some helpful info:
Click here > www.kzrider.com/forum/4-electrical/57866...r-cover-issue#578661
Good Fortune! :)
