Conversion question
  • geohaydook1
  • geohaydook1's Avatar Topic Author
Conversion question
05 Nov 2013 22:07
#612206
Is it possible to convert a shaft drive 750 engine to chain drive?
1980 KZ750e
1981 KZ650 csr (fate undecided)
  • koolaid_kid
  • koolaid_kid's Avatar
Re: Conversion question
06 Nov 2013 05:48
#612223
Anything is possible if you throw enough money at it.
Is it practical, no. Better to swap the engine/bike for a chain drive if that is what you want.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • geohaydook1
06 Nov 2013 17:35
#612273
Thanks, I was just currious.
1980 KZ750e
  • peavylotus
  • peavylotus's Avatar
  • Movin on up
07 Nov 2013 07:39
#612317
I saw a thread on here once about it. I can't find it but I believe you change the output shaft on the transmission, put a new sproket cover and sprocket as well as a wheel, chain and swing arm. You could get a cheap blown up engine and do a swap cheap. It doesn't look too hard. Here is a thread from streetfighter on a swap.
1980 KZ 1045 LTD Currently Workin' It Out
