Cam holder bolt stripped - Need advice
- -[DawG]-
Hope all is well.
I started a 1980 KZ750-E as a long term project some time ago, but a very rude thing happened to me.
I borrowed a torque wrench from a workshop to torque the head and cam holders after valve clearance adjustment, but I never tested the wrench before use. I adjusted it to the required torque value, but 1 bolt stripped the thread on the top end. I asked another guy to try and fix it, and he rammed a bigger bolt into the whole without much result.
Now, the problem: The amount of metal left is not enough to do an inset, as a mm more would touch the cam, and the bolt that is currently in there can only be torqued to about 7-8nm... The bolt is long enough that it would not run around the top end if it comes loose, but it does not torque well.
How big of a problem do you guys think I'm looking at? Should I get the top end welded and rethreaded or should I leave it be?
The bike started fine but I dont want to run it like this knowing something might go horribly wrong
Any advice or opinion would be highly valued.
Kindest regards,
H
"Everything has beauty, but not everyone sees it."
1982 KZ750R - Sold
1980 CX500 - Sold
1980 KZ750-E1 - Project
GSXR1100 SS - Future Project
2000 CBR600F4 - Sold
2008 DRZ400SM - Sold (Biggest mistake EVER)
2007 KTM 200 XCW - Smokin Toy
- baldy110
- Thank you received: 512
- 4TheKZ1000
- Visitor
The cam cap bolts are 6mm and thread pitch is 1.0 with its length at 38mm. It looks like the threaded portion of bolt is about 50% of the bolt, so a 20mm timesert looks to be correct.
www.timesert.com/html/mtrcsert.html
www.cmsnl.com/kawasaki-1980-kz750-e1_mod...head-6x38_920011105/
- Cynjut
- Thank you received: 26
The timeserts I've used have a shoulder that binds the insert into the hole to keep it from backing out when you wrench on it later. This shoulder can sit proud of the hole and cause the cam cap to not seat correctly. A 15 or 20 mm helicoil will sit completely inside the cam cover base and (if inserted correctly) will never sit proud.
For spark plugs and other places where the shoulder height isn't critical, Timeserts are definitely the way to go. In this one case, I prefer HeliCoils.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
- 4TheKZ1000
- Visitor
__________________________________________________________________________________________Cynjut wrote: While I'm a believer in Timeserts, this might call for a heilcoil instead.
yep, your right. could use a full thread bolt with no shoulder....could drill out poor threads and re-tap for a 1/4 sae bolt....this is a common idea.
- Cynjut
Instead of that, I've heard of people replacing the 6mm bolts by tapping the holes out to 7mm, which is what the tap for the helicoil is. The trick with the 7mm tap is that you don't have a second 'bite at the apple' if you over-tighten your cam cap bolts again. You can't go to 8mm (IIRC) because the inside diameter of the alignment collars are 7mm, and going to 8mm doesn't give the collars enough shoulder to work reliably.
By The Way! The reason these so commonly strip out is because the books all have the torque for this bolt wrong - they all list 144 in pounds (12 ft pounds). These 6mm bolts should never be torqued more than 90 in pounds. The "right" torque is something like 84 in pounds. I stripped out about half the bolts in my KZ1000 trying to use 12 foot pounds. That was also when I figured out the TimeSert versus Helicoil difference.
1977 KZ-1000 A1
