KZ1000 Timing (right side) cover interchange?
  • Stazi
  • Stazi's Avatar Topic Author
25 Oct 2013 13:35
#611137
Can someone tell me if the 14027-023 right side timing cover from say a 78 KZ1000 will fit on a 82 KZ1000 that normally uses the 14025B cover? I would like to use the 14027 with the "DOHC" logo on my bike as my timing cover is scratched.
TIA!
82 KZ1000-K2 LTD
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: KZ1000 Timing (right side) cover interchange?
25 Oct 2013 14:10
#611145
The short answer is no. The later generation KZ has a pulsing coil/governor-breaker that sticks out slightly further than the earlier generation KZ1000's. Note that the later generation pulse cover is slightly thicker/deeper to accommodate this. However, this later pulse cover will fit on an earlier generation KZ...which doesn't help you at all. :huh:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
The following user(s) said Thank You: Stazi
  • Stazi
25 Oct 2013 14:19
#611148
Okay, thanks! I understand what you're saying completely. I guess I will just try and find a better condition later version cover.
82 KZ1000-K2 LTD
  • Beaner242
  • Beaner242's Avatar
25 Oct 2013 20:01
#611168
How much deeper is the later cover? Make a spacer maybe?
1982 KZ1000K LTD Chopper
