Nitrous Bottle Mounting
  • NakedFun
  • NakedFun's Avatar Topic Author
24 Oct 2013 15:40
#611045
Guys,
Looking for advice on where you have mounted one or two nitrous bottles? Thinking about a couple of polished 10/11Oz bottles that are 2" by 15" I want to take a look at what some have done so I can modify my frame to fit the mounts.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Nitrous Bottle Mounting
24 Oct 2013 15:50
#611046
I was hoping you were talking about the bigger 2/2.5lb bottles.:evil:
I'm not sure if the Sneaky Pete's have siphon tubes or not so orientation may play a factor. And are you wanting them hidden or exposed?
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • NakedFun
24 Oct 2013 16:07
#611049
The NX Express bottles have siphon tubes I believe, but I would have to confirm. Thinking of having them exposed since they and their mounts would be polished. Was considering having them mounted one on each side along the edge of the tail.
Cory
1976 Kawasaki KZ900
  • StreetfighterKz
24 Oct 2013 16:15
#611050
I went back to your build thread and along the tail may be the only logical place to mount the bottle(s). I was going to suggest running them parallel to the rear frame tubes but you're running rearsets and moved the upper shock mounts and would have no room. The other option is in front of the rear wheel and just behind the inner fender but accessing the valves would be awkward.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • NakedFun
24 Oct 2013 16:42
#611057
I think so as well. Unless I would modify the tail and mount them ins a twin side by side arrangement above the tail.
Cory
1976 Kawasaki KZ900
  • kzz1king
  • kzz1king's Avatar
24 Oct 2013 22:36
#611082
Scrape the tail and maki it a bottle carrier? The bottles could be the top and sides ofthe tail.
Wayne
Home built KZ1000 turbo setup
