Whats too much clearance on valves ?
  • KZB2 650
  • KZB2 650's Avatar Topic Author
23 Oct 2013 12:52
#610940
Bench shimmed my KZ650 at .0065 to .0075 on all 8 valves. 2 stayed within .0005, two opened up .001 and 4 stayed the same after bolting and torqueing it up.
Then at 100 miles and at 500 miles I checked em out. The 4 ex are right at .0055 to .0065 and one at .004 so I'll keep an eye on that #4 with .004.
The intakes have all stayed the same with 2 at .0075 and 2 at .007 although they were the opposite two at 100 and at 500 miles. Have 570 miles now. Pretty incrediable I think that they stayed so close considering APE did a complete valve job and replaced the guides.
What I quess I'm finally asking is .007 to .0075 ok for the intakes ?? I will admit it gets a little noisier after it warms. Hoping the Mobil 4t helps that a "little this spring". Just want to make sure running them at the max clearance does them no damage and if I figure right they will usually tighten up over the coming miles rather than get looser anyway right ?
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Re: Whats too much clearance on valves ?
23 Oct 2013 14:10
#610947
The gap on mine vary both tighter and looser, but they have stayed within the published spec since day one. The specified clearance is .08 - .18mm (0.0031 - 0.0071 inches). I doubt that the valves that are 0.0075" would cause a problem unless the gap opens up more. I would keep a close eye on them and see if they get tighter or looser and adjust them again if needed. Ed
  • 80B4
  • 80B4's Avatar
23 Oct 2013 18:30
#610962
Your valves will be fine if they are set to the widest spec. I have found the my bikes all idle better when I set them to the widest spec. The exhaust valves are the ones to watch.
1980B4 1000
1978 Z1R
1978 B3 750
  • mtkawboy
  • mtkawboy's Avatar
26 Oct 2013 06:39
#611205
They wont loosen up they will tighten up over time, loose is the better of the 2
  • KZB2 650
31 Oct 2013 06:10
#611684
Good deal guys ..... will wait till spring after putting a few more miles on it and loosen the ex valves up then. ;)
1978 KZ650 b-2
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
29 Nov 2013 18:35 - 29 Nov 2013 18:48
#614413
If they loosen up over time:
1. wear of shim
2. wear on cam lobe
3. loose bolt
4. wear on cam bearing
Last edit: 29 Nov 2013 18:48 by 4TheKZ1000.
