Engine Gasket Replacement
  • mcguest12
  • mcguest12's Avatar Topic Author
22 Oct 2013 14:22
#610833
Hello
I have a 1982 Kawasaki KZ750 Spectre. I have a few oil leaks around the gaskets on the engine, I would like to take this apart and replace all gaskets from the bottom up.
Is this a good idea? What other problems can I run into when doing this? Is there anything else I should be looking at replacing while I have it apart.
Do I have to take the valves and shims out when doing this? Any ideas or assistance would be great.
  • pbmax
  • pbmax's Avatar
Re: Engine Gasket Replacement
22 Oct 2013 14:41
#610834
First try re-torqueing the head and case bolts.
No, valves/shims do not need to be removed for gasket replacement. But you should check valve clearance.
  • lindseyss
  • lindseyss's Avatar
22 Oct 2013 19:46
#610869
But if he does from the block up then the cylinder will have to come off. And might as well replace the rings while he is there.
