Junking an engine
- mtbspeedfreak
Junking an engine
19 Oct 2013 21:26
Hey folks,
I'll eventually be selling or junking the original beat up and seized motor for my Z1B. I will be keeping the top engine case (with the numbers accurate VIN and the 900 pork chop crank. Is there anything else worth keeping? The head has broken fins from a bad crash, other than that, I have no clue.
2000 ZRX 1100
1976 KZ 900- Daily Driver
- Nebr_Rex
Re: Junking an engine
19 Oct 2013 21:56
Anything usable. And the cases are machined as a unit.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- racer54
19 Oct 2013 21:57
I'd keep both case halves. I believe they are machined as a set.
19 Oct 2013 21:57
Don't just keep the top engine case; keep the bottom engine case with it. They are machined together, so one without the other is not worth much. Ed
- testarossa
19 Oct 2013 22:39
The block can be re-sleeved. I have pulled the sleeves out of a block before. In fact, I have an old propane grill that serves the purpose quite well.
What kind of shape is your cam cover in? Oil pan? I might be interested in that stuff if you want rid of it. I'm slowly accumulating parts for a super secret back burner project. Let me know before you decide to scrap it out. I'm sure I can do better than the going rate for aluminum scrap if you want rid of this stuff.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- mtbspeedfreak
19 Oct 2013 22:54
Good to know - I knew the cam caps and head were machined as one, I learned about the two cases machined as one.
Testa - you got it. It'll be a month or two before I dig into this thing, but I'll give you a shout well before I pitch anything.
2000 ZRX 1100
- MFolks
19 Oct 2013 23:19
www.lasleeve.com
seems to make the best sleeves.
