- Thank you received: 31
Fuel Injection Question
- GPzEric
Does anybody know if the program in the ECU is the same for all of these, or do the non-emission bikes have a different program/ fuel MAP ?
The ECU's appear to have the same part number, and are about as smart as a 1982 vintage 'Pong' game - Ha Ha -so I upgraded to a 1984 ECU that has the rev-limiter, 'limp mode', and diagnostic light, and I've got an extra rack of the 1984 fuel injectors that I'm deciding whether to carefully put away, or send them off and have them smooth-bored.
Whaddya think - same program for all, or different for US Spec ?
My wife asked me if I still loved her - I said "Honey, I love you more than new carburetor boots ! "
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
(2) 1981 KZ550D1 (GPz) 1 mint, 1 under construction
1983 GS1100E
- Motor Head
- Thank you received: 391
- Mcdroid
- Gone Kwackers
- Thank you received: 317
Interesting modification you did using the later electronics...I also picked up a 1983/84 ZX1100 ECU and a set of ZX1100 cams with the eventual goal of converting my 1982 model GPz1100.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- GPzEric
Right now the 1136cc 10.25:1 engine is about the equal of my '83 GS1100 in the mid-range, but when the needle swings past 7000 rpm it's all over.
I'm still debating about the injectors - and right now I'm going to pull the injectors off, clean and lube the rack, and vacuum-seal it and put it away in case I need it later. I did the same thing with the extra TPS, and extra sensors - Kawasaki doesn't make them anymore, and I don't want to be broken down one day in need of an unobtainable part !
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
1983 GS1100E
- MFolks
- Thank you received: 540
Fuel Injection Cleaning/Calibration Services
www.witchhunter.com
www.injectorrx.com/services.html
www.injector-rehab.com/
- GPzEric
The tip on the Honda starter worked out well - you should hear how easy the Honda starter cranks over the bik Kawi -
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
1983 GS1100E
- MFolks
- Mcdroid
- Gone Kwackers
GPzEric wrote: Thanks Mfolks - I've studied your GPz-related posts more than you know.
I actually have many of Mike's posts printed out and velo-bound for reference.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Lorcan
- Speed Loony
- Thank you received: 59
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- steell
In 1982 Atari 800 was available (I bought one of them also).
- jeffasaki
- Thank you received: 44
Lorcan wrote: Change to high impedance injectors and you can run a Powercommander 3 just like a modern bike. That way you can adjust the map for different exhaust etc., or even a different engine. And pretty much every dyno operator is familiar with the Dynojet software.
What injectors? do you have a P/N
sounds like a easy upgrade
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Lorcan
- Speed Loony
760cc - 8.69@162mph
