carb sync needed
- emptypond
carb sync needed
16 Oct 2013 23:28
Anyone in the greater RI area have a carb sync tool I can borrow? I'm planning on getting one, but not in the next few months. Thanks!
81 kz750 frame, with an 83 kz750 engine.
- Motor Head
Re: carb sync needed
16 Oct 2013 23:58
Have a look at this in File Base, quick cheap and easy to build. Actually very sensitive to adjustment.
www.kzrider.com/filebase/doc_download/18...fferential-manometer
- emptypond
18 Oct 2013 15:09
Thanks motor! I'm not very knowledgeable on the workings of the manometer, but I suppose for $10, I could learn! I'll try this this weekend and see how it goes. Much appreciated. I suppose I should try and use the resources on the site a little better too..
- emptypond
18 Oct 2013 20:23
I just read through the instructions. It's really that simple? Tuning all carbs to each other using a vacuum "balance"? I guess I've found my weekend project.... Thanks again!
