Repairing holes in exhaust
  • bemoore
  • bemoore's Avatar Topic Author
16 Oct 2013 14:49
#610232
A while ago, I bought a stock exhaust system for my 650C1 off ebay. I failed to notice that it had holes in the end of one side. So now I need to find some way to repair this. Any ideas?
77 KZ650C1 w/Kerker 4-1
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Repairing holes in exhaust
16 Oct 2013 15:04
#610235
I can't really think of an elegant solution but a plate that looks like a giant washer could be made then welded to cover all the holes at once. But you'll have exposed weld beads that should be coated to prevent rust.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • martin_csr
  • martin_csr's Avatar
16 Oct 2013 15:13 - 16 Oct 2013 15:14
#610236
Possible internet searches: motorcycle end caps, muffler tips, exhaust caps, exhaust baffles, tips
Replacement mufflers.
EMGO UNIVERSAL DUNSTALL STYLE MEGAPHONE MUFFLER
HELIX RACING UNIVERSAL DUNSTALL TYPE EXHAUST MUFFLER
Verner-650's bike w Dunstall Replicas
Last edit: 16 Oct 2013 15:14 by martin_csr.
  • nickleo373
  • nickleo373's Avatar
16 Oct 2013 15:23
#610237
Are you sure it's not used as a drain hole?
1981 KZ550C LTD
"If you ain't first, you're last"
  • bemoore
16 Oct 2013 15:28
#610238
StreetfighterKz wrote: I can't really think of an elegant solution but a plate that looks like a giant washer could be made then welded to cover all the holes at once. But you'll have exposed weld beads that should be coated to prevent rust.
Later, Doug
I thought of doing something like that. Would JB Weld be able to hold the "washer" in place without welds?
  • bemoore
16 Oct 2013 15:32
#610240
martin_csr wrote: Possible internet searches: motorcycle end caps, muffler tips, exhaust caps, exhaust baffles, tips
Verner-650's exhausts look nice, but I'm interested in an actual stock exhaust. I would have no confidence with an aftermarket system that it would run as well as stock. It may flow better, but it will not flow exactly the same as stock, so stock jetting won't work. I have a Kerker now. If I decide to not go stock, I'm going to stick with the Kerker.
Thanks.
  • Cynjut
  • Cynjut's Avatar
16 Oct 2013 15:48 - 16 Oct 2013 15:49
#610243
As long as you don't make a crazy changes to the exhaust, most mufflers will react similarly to stock. The holes in your exhaust were probably added by the previous owner to get the to sound 'better' and to reduce back pressure.
As long as you haven't removed the airbox from your bike, this simple change should be fine, performance wise. The slight reduction in back pressure shouldn't require you to rejet, but you may need to tune the carbs slightly.
While some carbs sets (Keihin BS carbs, for example) do not react well to any changes in the performance envelope, others (like the Mikunis) are more tolerant of changes.
We're kind of 'rule of thumbing' the advice. Since your bike is a '77 and probably has Mikuni 26mm or 28mm carbs, you can make some pretty radical changes to EITHER the exhaust or the intake and not have to do a thing. My '77 KZ1000 ran without a single change to the tuning when I pulled the original exhaust and replaced it with a 4-into-1 high performance rig. Put on pod filters and a high performance exhaust and you might have to rejet.
Because of the way the Constant Velocity (Keihin) carbs actually operate, even slight changes translate to huge changes in carb performance.
Good luck.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
Last edit: 16 Oct 2013 15:49 by Cynjut. Reason: Found more info
  • bemoore
16 Oct 2013 15:54
#610245
nickleo373 wrote: Are you sure it's not used as a drain hole?
Yes, I'm sure. The other side doesn't have these holes.
  • Cynjut
  • Cynjut's Avatar
16 Oct 2013 16:34 - 16 Oct 2013 16:35
#610254
I noticed that there are screws in the ends of the mufflers. Have you tried removing those to see if the baffles are removable?
1977 KZ-1000 A1
Last edit: 16 Oct 2013 16:35 by Cynjut. Reason: Carbs? Really?
  • bemoore
16 Oct 2013 16:42
#610256
Cynjut wrote: I noticed that there are screws in the ends of the mufflers. Have you tried removing those to see if the baffles are removable?
No, I haven't tried that. I'll give that a try.
  • Nebr_Rex
  • Nebr_Rex's Avatar
16 Oct 2013 16:44
#610257
Cynjut wrote: As long a
Good luck.
Keihin??? :whistle:
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Nebr_Rex
  • Nebr_Rex's Avatar
16 Oct 2013 16:45
#610259
Good luck removing them screws.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
