Loud click, low compression, was low on oil
- tomccrowe
14 Oct 2013 23:30
I was hoping you all could help me. I have a 1978 KZ650 and it has run great all summer and I never noticed it burning any oil. The other day I did notice it smoke a little when I started it but didn't think anything of it. Well on the way home on the highway it started making a loud clack on the right side of the engine and lost power. After I got it home I checked the oil and it was very low if there was any in it at all. The compression on cylinder #4 is only about 50, all the others were over 100. I pulled the valve cover off and didn't see anything out of the ordinary. What could the problem be? I was hoping it would be something I could fix myself but now am kind of worried.
- bountyhunter
Re: Loud click, low compression, was low on oil
15 Oct 2013 04:15tomccrowe wrote: I was hoping you all could help me. I have a 1978 KZ650 and it has run great all summer and I never noticed it burning any oil. The other day I did notice it smoke a little when I started it but didn't think anything of it. Well on the way home on the highway it started making a loud clack on the right side of the engine and lost power. After I got it home I checked the oil and it was very low if there was any in it at all. The compression on cylinder #4 is only about 50, all the others were over 100. I pulled the valve cover off and didn't see anything out of the ordinary. What could the problem be? I was hoping it would be something I could fix myself but now am kind of worried.
Clues:
NO OIL
LOUD CLACKING NOISE
LOST POWER
My silly guess would be a rod or main bearing is hosed.
The following user(s) said Thank You: BlackZ1R
