'82 KZ1000K2 LTD - Oil leak top of crankcase
  • The_Raven
  • The_Raven's Avatar Topic Author
13 Oct 2013 17:24
#609877
Hi all,
Doing some post-ride polishing, I noticed some oil near the starter cover. The engine was still hot so I really couldn't do a lot of poking around. Where are some common spots to check/tighten in the area?
[IMG
-Mark P.
Salem, MA
Widowmaker, 1982 KZ1000J2 @1100cc
Red Scare, 1994 Honda VF750C Magna
I intend to die from living.
  • P21
  • P21's Avatar
Re: '82 KZ1000K2 LTD - Oil leak top of crankcase
13 Oct 2013 17:35
#609879
the oil sending unit.
Kawasaki KZ 1000 Police (2002) P21
The following user(s) said Thank You: The_Raven
  • Motor Head
  • Motor Head's Avatar
13 Oct 2013 17:44
#609880
There are 3 o-rings under the adapter for the oil sending unit. These leak. 2 are the same size with 1 smaller o-ring around the bolt. Also 1 o-ring for the sending switch.
  • Puffin
  • Puffin's Avatar
13 Oct 2013 18:01
#609884
The Oil sender pressure switch area was my thought also :)
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
  • The_Raven
14 Oct 2013 19:59 - 14 Oct 2013 19:59
#610010
Bingo! You guys nailed it. I've ordered up the o-rings.
Here's the lil' bastard in action (right near the end of the vid)
-Mark P.
Salem, MA
Last edit: 14 Oct 2013 19:59 by The_Raven. Reason: video goofed
  • Motor Head
14 Oct 2013 22:40
#610025
Should be an easy fix, just a 6mm allen wrench to remove the bolts.
  • The_Raven
19 Oct 2013 20:58
#610546
Replaced the o-rings today, along with a missing washer. The old o-rings had hardened to the consistency of plastic, the new ones are nice and pliable. Had a helluva time getting the allen bolts loose - took a lot of time, patience, penetrating oil and finally a little extra leverage to break 'em free. Looks great now, did a quick test and all looks dry. Thanks all!
:cheer:
-Mark P.
Salem, MA
  • Beaner242
  • Beaner242's Avatar
20 Oct 2013 00:24
#610586
Where did you get them?
1982 KZ1000K LTD Chopper
  • The_Raven
20 Oct 2013 02:54
#610597
Z1 had some, but unfortunately not all of the parts, so I ordered them from BikeBandit. It was about $20 for the lot.
Here's the order:
Code:
"O" RING,9MM 851783 2 $5.06 Shipped "0" RING,18MM 851791 2 $1.62 Shipped WASHER 858541 2 $6.14 Shipped "O" RING 864646 2 $6.76 Shipped
-Mark P.
Salem, MA
  • Puffin
  • Puffin's Avatar
20 Oct 2013 10:32 - 20 Oct 2013 10:33
#610611
Excellent Raven, pleased you sorted it ! No one likes an oil leak :evil:
KZ1100
Last edit: 20 Oct 2013 10:33 by Puffin.
