Oil pressure issues
- Powerstroke_fan
Oil pressure issues
10 Oct 2013 20:15
I need some advice guys. Iam stumped. It all started last week me and buddy was out riding around our area. My oil cooler ended up getting a hair line fracture in the tank. I later found out that i must of came down to hard on it once and it hit the cooler. Well anyways we were messing around and i got on it and thats when my cooler let loose. I felt the oil on my leg. So i limped it home with the cooler leaking some. The oil light never came on and i was only about a 1/2 mile from the house. Soon i got back i checked the oil and it still had oil in it but it was low. Never had the first oil pressure light. Well i purchased a 13 row oil cooler from earls. I put the fittings down. I added oil and started it and it started up and the oil pressure light went off like normal. I let it sit for a couple seconds idling. No light. Started off down the road and i was babying it and i seen my light flicker. Then it did it again. From then on it stays on below 3 grand. I tried flipping the cooler over. I checked and changed the oil pressure sensor. Iam stumped. I checked all the passage ways. I blew thru the cooler. But you can take the line off and start it and when the pressure light is on its not pumping. But rev it up and light goes out and it starts pumping. And no before you ask i didnt run it for but just a few seconds with the line unhooked. So i pulled the pan and changed the pump, oil and filter. And the light still comes on. I havent tried any thing since i installed another pump and checked all passages to oil pressure sensors. But the light still comes on below 3 grand. But goes out and stays out above 3 grand. Any ideas would be greatly appreciated.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- 4TheKZ1000
Re: Oil pressure issues
10 Oct 2013 20:22 - 10 Oct 2013 20:33
No eBay APP ID and/or Cert ID defined in Kunena configurationI purchased an oil pressure gauge. I run between 3 and 6 pounds. I just don't trust the light. You might get the gauge so you would know what the pressure really is all the time.
I have this one and couldn't be happier.
Last edit: 10 Oct 2013 20:33 by 4TheKZ1000.
- Powerstroke_fan
10 Oct 2013 20:42 - 10 Oct 2013 20:42
Ya i need one, ill have to see about getting one. but dont have one right now. Should also mention i inspected everything in the crankcase that you csn see from the bottom. There wasnt any shaving in the motor it still starts right up and runs like normal.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 10 Oct 2013 20:42 by Powerstroke_fan.
- racer54
10 Oct 2013 21:17
Have you tried another pressure sensor to make sure it works correctly?
- Powerstroke_fan
10 Oct 2013 21:49
Ya, i changed that first.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Motor Head
10 Oct 2013 22:49 - 10 Oct 2013 23:02
Have you checked the pressure regulating valve when you had the sump down?
Spring and ball in both the oil filter bolt assy, and 3- 4 here in the fiche.
Last edit: 10 Oct 2013 23:02 by Motor Head.
The following user(s) said Thank You: Powerstroke_fan
- Powerstroke_fan
11 Oct 2013 08:05
I did glance at it and it was kinda reccessed into the hole some instead of flush.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
