Gear ratio change on shaft drive?
10 Oct 2013 17:09 #609550 by 83KZ750LTD
Gear ratio change on shaft drive? was created by 83KZ750LTD
I was wondering if anyone knew if the final drive can be changed to a different ratio on a shaft drive 750 LTD. I'm doing near 5k rpm at 70MPH while in 5th gear and I would like to get a bit more MPG.
Anyone have any input?
1983 KZ750-F1 LTD - 8000 miles - 2/2015 - Head gasket time!
  • Motor Head
10 Oct 2013 23:07 #609592 by Motor Head
Replied by Motor Head on topic Gear ratio change on shaft drive?
You can make a small change with a different rear tire, taller ratio. In metric this usually means wider at the same time.
What rear are you running now?
Otherwise the final drive or the engine bevel gear would have to be swapped, and that could prove expensive depending on what would fit and how much you could get it for.
11 Oct 2013 09:58 #609630 by 83KZ750LTD
Replied by 83KZ750LTD on topic Gear ratio change on shaft drive?
For the rear tire I'm running the OEM spec size 130/90/16. I was hoping I could get a different bevel gear set to keep the stock look. I've searched around but I can't find anything and I don't have the time or the energy to go compare the sets on other bikes in a boneyard.
11 Oct 2013 10:20 #609635 by koolaid_kid
Replied by koolaid_kid on topic Gear ratio change on shaft drive?
Unfortunately, that is one of the pitfalls of a shaft drive. You are stuck with the ratios the engineers gave it at the factory. Seems like it would be a lot of work and probably money to make any sort of changes.
For the record, 5k at around 70 mph sounds about right for a 750, which is a motor that needs to keep the revs up to make any power.
Best of luck.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
11 Oct 2013 11:44 - 11 Oct 2013 11:49 #609645 by Patton
Replied by Patton on topic Gear ratio change on shaft drive?
83KZ750LTD wrote: I was wondering if anyone knew if the final drive can be changed to a different ratio on a shaft drive 750 LTD. I'm doing near 5k rpm at 70MPH while in 5th gear and I would like to get a bit more MPG.
These engines were born to spin at their designed road speeds, and they happily do so.
Ideally, there's a sweet spot where the engine is performing at maximum efficiency, where the rpm is "just right" for the load and road speed.
Neither over-revving (such as constant cruising in a lower gear), nor under-revving (such as more lugging effort resulting from too tall gearing).
Stock gearing usually produces the better compromise between acceleration and cruising.
Consider that the maximum road speed of a stock Z1 is about the same in either 4th or 5th gear.
Imo, ideal highest gearing produces top speed just as engine rpm meets red-line.
In other words, where a properly performing engine will barely pull red-line in top gear.
Taller overall gearing may require less rpm for a more relaxed feeling at cruising speeds, but at the expense of reduced acceleration.
Conversely, lower overall gearing may afford quicker acceleration, but at the expense of a more frenetic unnecessarily higher rpm at cruising speeds.
Taller gearing doesn't necessarily result in higher mpg. And may result in lower mpg.
Where the engine is running in its sweet spot at a given cruising speed, changing to taller gearing that moves it out of its sweet spot -- although at a lower rpm -- requires the engine to work harder at the lower rpm, and actually perform less efficiently.
Just my 2¢.
Good Fortune! :)
Last edit: 11 Oct 2013 11:49 by Patton.
11 Oct 2013 13:15 #609660 by Cynjut
Replied by Cynjut on topic Gear ratio change on shaft drive?
All of that's good information.
In addition, fuel economy is more of a function of the amount of work the engine has to do to get you and keep you at speed. Changing the gearing for your bike to get better MPGs at highway speeds isn't going to work the way you want it to.
Even if you go for a lower RPM, you're still going to have to provide EXACTLY the same horsepower to the wheel to stay at a particular speed. You are overcoming resistance (roll, mechanical, and wind) at that speed.
Changing the location in the power band that the engine is running at when at your desired cruising speed is the only way to affect fuel economy without changing other resistance factors. This is deep science, and is dependent on the particulars for your engine.
For other considerations (acceleration, etc.), changing the gearing can be very effective, but for your stated purpose (better MPG) I don't think you are going to see a difference and there's a 50/50 chance that you actually make your mileage worse.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
11 Oct 2013 18:02 #609682 by 83KZ750LTD
Ok this is all good information. I think I need to find the root issue as to why my fuel is empty just after 125 miles. I'm running stock on every thing and a spark plug inspection tells me the air/fuel mixture is perfect. The engine runs smooth and only has 8000 miles on it.
I guess I expect better than 27 mpg on a bike.
11 Oct 2013 18:24 #609687 by koolaid_kid
That does seem low. I would have expected low to mid 40s.
1983 GPz 750
11 Oct 2013 19:00 #609692 by Cynjut
I'd also expect about 50% better mileage.
Check your carb float height. If you are running too high, you could lose a considerable amount of fuel to the overflow.
Check your fuel line for leaks. You could be losing gas when you're moving, which would cause this kind of fuel economy problem.
Check your valve lash. Marginal valve clearances can rob you of mileage by robbing you of power.
Check your timing. If you're running with your timing retarded (not you personally), you'll have to supply a lot more gas to get to the same level of power from the engine.
1977 KZ-1000 A1
11 Oct 2013 19:15 #609693 by 650ed
Replied by 650ed on topic Gear ratio change on shaft drive?
83KZ750LTD wrote: Ok this is all good information. I think I need to find the root issue as to why my fuel is empty just after 125 miles. I'm running stock on every thing and a spark plug inspection tells me the air/fuel mixture is perfect. The engine runs smooth and only has 8000 miles on it.
That is pretty low unless you're really running hard. I've always gotten 34 - 42 depending on how hard / fast I'm riding. Check the fuel level using the clear tube method. Ed
Attachment ClearTubeTest.jpg not found
11 Oct 2013 19:28 #609694 by martin_csr
Replied by martin_csr on topic Gear ratio change on shaft drive?
Are you calculating the mpgs correctly?
I'd guess the tank is ~3.2 gallons total including a reserve of about 0.7 gals.
3.2 gals x 40 mpg = 128 miles
If your bike has a low fuel warning light, it would illuminate at 100 miles when getting 40 mpgs.
  • Motor Head
11 Oct 2013 23:27 #609724 by Motor Head
You can get a 140 tire, that will add a bit of both height and width, small increase in gearing.
That fuel mileage if right is terrible unless your hammering on it. You should go do basic maintenance first, paying close attention to things like posted already. Carbs, Ignition including Voltage to coil check, Filters, Tire pressures, and such. Look close at the ignition advance and make sure it is moving freely and in spec. My shaft drives, I have been running synthetic gear oil to help cut friction.
