1981 LTD1000 changing the cylinders to 83 Kz1100.
  • lindseyss
  • lindseyss's Avatar Topic Author
05 Oct 2013 17:01
#608868
This is a 81 ltd1000 with the J1 motor. I have found a 83 kz1100 cylinder and factory pistons. Is there any gottcha's to doing this swap?
The following user(s) said Thank You: Lt.Dan
  • dbc92s10
  • dbc92s10's Avatar
Re: 1981 LTD1000 changing the cylinders to 83 Kz1100.
05 Oct 2013 19:53
#608884
get a different set of pistons yours have the 17mm wristpins and the 83 has the 18mm wristpins
81 ltd1000
1135 mtc 10.5/1
cavanaugh racing head
38.6/32 p&p
APE k410 cams
APE hardware and tensioner
84 gpz1100 trans
kerker w comp baffle
rs36 carbs
fast by gast race crank
  • Puffin
  • Puffin's Avatar
05 Oct 2013 20:50
#608888
lindseyss wrote: This is a 81 ltd1000 with the J1 motor. I have found a 83 kz1100 cylinder and factory pistons. Is there any gottcha's to doing this swap?
I have a KZ1100 cylinder and pistons mounted on one of my J motors wrist pins are 17mm so plug and play, just use the 1100 gaskets ;)
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
The following user(s) said Thank You: lindseyss
  • Nebr_Rex
  • Nebr_Rex's Avatar
05 Oct 2013 22:07
#608891
Your both right, lindseyss have you measured the 1100 wrist pins?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • lindseyss
05 Oct 2013 22:49
#608894
I was told the 81-83 on the kz1100 had 17mm pins but the 84 up had 18mm I will measure them.
  • lindseyss
06 Oct 2013 11:56
#608923
I measured the pins and they are 17mm. What I have been told is 81-83 kz1100 or 81-82 gpz1100 cylinder and pistons will work.
  • Motor Head
  • Motor Head's Avatar
06 Oct 2013 11:57
#608924
18mm is the GPZ 1100. 17mm for the KZ, LTD, CSR, Spectre, Shaft Drive A3 sport touring.
If your bore/ pistons are worn, you can get a big bore kit for the 1100 block.
  • OnkelB
  • OnkelB's Avatar
06 Oct 2013 12:30
#608927
GPz 1100 B1 and B2 (KZ 1100 81 and 82) have 17 mm wristpins, 83 and up (the ZX 1100 UniTrak models) have 18 mm wristpins.
77 KZ 650 B1, 82 GPz 1100 B2.
  • lindseyss
07 Oct 2013 21:35
#609177
I want to use my kz1000 head just had everything adjusted on mine. Do I have to go to the 1100 head? The compression will be greater with the 1000 head I think?
  • Puffin
  • Puffin's Avatar
08 Oct 2013 04:22
#609221
You can use your 1000 head they are of the same casting :)
KZ1100
  • lindseyss
08 Oct 2013 21:13
#609307
I talked to a guy in CA and he said this is the easiest way to increase performance. It is only a cylinder a piston swap. Everything else is the same. So I have my winter project.
  • lindseyss
08 Oct 2013 21:46
#609311
I was told this was the way to go. It is more rideable than boring the 1000 cylinder and changing to 1075 pistons.
