Oil leaks from valve cover
  • nickleo373
  • nickleo373's Avatar Topic Author
03 Oct 2013 22:59
#608711
Hey everyone
I was turning my bike on the other day and noticed when I had it choked to start up there was a small amount of oil coming from the valve cover gasket. My choke for some reason will shoot the rpms to 5 or 6k when it's on full to start the bike up. It seems that it only leaks when the engine is in higher rpms and the leaks only come from the left side of the engine. Is this a gasket that needs to be replaced or something else?
1981 KZ550C LTD
"If you ain't first, you're last"
