GPz 750 Reed Valves
  • freakinbike
  • freakinbike's Avatar Topic Author
GPz 750 Reed Valves
02 Oct 2013 01:04
#608528
What do the reed valves on the GPz 750 cam chain cover do? Would there a benefit from deleting them (ie getting a head cover without reed valves)? If so, are other modifications required?
1982 GPZ750, stock (for now..)
1973 VW Bus
Can life really get much better?
  • Motor Head
  • Motor Head's Avatar
Re: GPz 750 Reed Valves
02 Oct 2013 09:09
#608543
They are for the Fresh Air Emission System. Fresh Air Is drawn into the Exhaust port, to help reduce emissions. Like the old Air Pumps used on cars from the same period. They do no harm to your motor. You can delete it if you don't have Emission testing in your area. There are block off plates sold, APE has them kzzone.com/billet.html
Your service manual will show the related parts, the Air Switching Valve, and vacuum lines.
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
02 Oct 2013 16:07
#608582
Connect the two covers with a piece of hose.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
