Help!!! Bike won't start
  • smjohnston88
  • Topic Author
  • Visitor
28 Sep 2013 14:28 #608127 by smjohnston88
Help!!! Bike won't start was created by smjohnston88
I just had my engine rebuild carbs are clean and synced, valves are good, it just won't start. I checked the coils theyre good, the only thing is my bike leans alittle much on the kickstand, I was wondering if that could be a problem? Maybe causing the gas to go to one side of the carbs. I'm just really at a lose here any help or suggestions would be greatly appreciated.
28 Sep 2013 14:47 #608129 by MFolks
Replied by MFolks on topic Help!!! Bike won't start
What model and year of bike?
  • smjohnston88
  • Topic Author
  • Visitor
28 Sep 2013 14:52 #608130 by smjohnston88
Replied by smjohnston88 on topic Help!!! Bike won't start
77 650s
  • PaulyWally
  • Total Bike Newbie
28 Sep 2013 16:51 - 28 Sep 2013 16:54 #608135 by PaulyWally
Replied by PaulyWally on topic Help!!! Bike won't start
smjohnston88 wrote: I just had my engine rebuild
Can you elaborate?
How long ago was the engine rebuilt? Was the bike running/starting OK before the engine was rebuilt... and as soon as the bike was put back together it wouldn't start?
More specifics would be helpful. But the first thing I would do is pull the plugs, check 'em for spark, and while they are out do a back-alley compression check. It won't cost you anything more than a half hour, and might get you on the right path.
Back-Alley Compression Check: Pull the spark plugs and press your thumb hard into each spark plug hole and turn the engine. If there isn't enough air pressure to break your thumb seal, you've got no compression.
1976 KZ750 Twin
Last edit: 28 Sep 2013 16:54 by PaulyWally.
28 Sep 2013 16:59 #608136 by 650ed
Replied by 650ed on topic Help!!! Bike won't start
Put your bike on the center stand.
Turn the petcock on.
Turn the kill switch to run.
Pull the choke on.
Turn the key on.
DO NOT TOUCH THE THROTTLE.
DO NOT PULL IN THE CLUTCH LEVER.
Use the kick starter and kick it.
It should start.
