KZ550 Oil Filter Bolt Leak
Re: KZ550 Oil Filter Bolt Leak
27 Sep 2013 23:32
#608072
Dr. Gamma wrote: I thought the o-ring for the oil filter bolt was 670B2016, not 670B1508.
670B1508 is only 8mm in diameter.
Thanks, Dr. Gamma! :cheer:
Edited accordingly.
Good Fortune! :)
  • RonKZ650
  • RonKZ650's Avatar
27 Sep 2013 23:38 - 27 Sep 2013 23:42
#608074
Last edit: 27 Sep 2013 23:42 by RonKZ650.
  • RonKZ650
  • RonKZ650's Avatar
27 Sep 2013 23:40
#608075
One thing I've learned over the years is to not replace parts that are not causing problems. Orings are on this list, mostly if not exact Kawasaki part. The oring on the filter bolt will last 100,000 miles, no need to change unless it's leaking.
  • Dr. Gamma
  • Dr. Gamma's Avatar
28 Sep 2013 00:03
#608080
Agreed with you on the o-rings.
I can't even remember the last time I replaced the o-ring on the filter bolt. When I change the filter, I never pull the filter bolt out from the filter cover. I wash both off in the Safety Kleen machine,oil the rubbers on the filter and twist the filter down into place. You can't imagine how many people throw the little steel washer away when they change the filter!!! I use a few dabs of grease to hold the big o-ring in place for assembly.
I think most people damage the o-ring on the filter bolt because they don't lube the o-ring when they pop it into the filter cover.
1986 RG500G 2 stroke terror.
  • loudhvx
  • loudhvx's Avatar
28 Sep 2013 00:14
#608084
Agreed, in 20 years, I think I have maybe replaced one, just out of curiosity. Still using it.
The only time I had a massive leak was when the large o-ring came out of the groove somehow while installing the filter.
  • Dr. Gamma
28 Sep 2013 00:54
#608087
loudhvx wrote: Agreed, in 20 years, I think I have maybe replaced one, just out of curiosity. Still using it.
Thats why I use the dabs of grease in the groove to keep the o-ring in place during installation.
  • Pzero
  • Pzero's Avatar Topic Author
28 Sep 2013 11:37
#608108
Well, I took it back out, everything looked snug and was all there. Then I put the bolt through the plate first and there seemed to be plenty of friction.
I put it back on the bike and tightened it a little past snug--there was a loud snap. The plate had broken in half.
Looking for a new oil filter plate, and while I'm at it I'll order a decent O-ring from Z1.
It's a six mile round trip walking to the bus stop to get to work. Bummer.
  • loudhvx
  • loudhvx's Avatar
28 Sep 2013 11:50
#608110
That plate is the same on many motors, so there should be plenty around for cheap.
29 Sep 2013 03:16
#608174
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationOil Filter Plate Part No. 13169-1110
Of possible interest --
Good Fortune! :)
  • Pzero
29 Sep 2013 07:06 - 29 Sep 2013 07:14
#608183
Thanks Patton!
I went ahead and ordered the cover from sbmotor.com (Southbay Motorsports) after reading some good reviews. I even called and talked to customer service and a very nice young lady double checked to make sure it was actually in stock.
I also ordered the correct 16mm O-ring and the right size flat washer from Z1 Enterprises, so I should be set. Oh yeah, time to pick up a new torque wrench so I don't crack the new cover. :S
Edit: the plate's okay, I cracked the cover (14025).
Last edit: 29 Sep 2013 07:14 by Pzero. Reason: additional info
