popping on deceleration...carb sync???
- dkoz
24 Sep 2013 16:40
a friend of mine told me to ride and adjust idal air screws ..and I trust his experience with this matter ..but any extra info on procedure to do this would greatly be appreciated that way ive got this post to come back to...im thinking this should be done before carb sync rather than after..its a stock ltd 1000 stock everything thanks
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
1978 Z1R D1
1978 A2
- KZQ
- Administrator
Re: popping on deceleration...carb sync???
24 Sep 2013 16:51
I wouldn't think the sync of the carbs would have anything to do with popping on deceleration. Is it possible that you have an exhaust leak at the pipe collar? If air can be drawn in there it can cause the problem you are experiencing.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
The following user(s) said Thank You: dkoz
- Forrest
- The Mad Duck
24 Sep 2013 17:08 - 24 Sep 2013 17:21
You are simply running leaner on deceleration. This is why you get the popping at those moments. It is usually not harmful. You can turn the air screws and enrichen the mixture. You are experiencing something that is quite normal on larger displacement motorcycles.
You say that the KZ1000 is stock. Does this include the carb jetting and exhaust? That is common for stock systems to run a bit on the lean side. If you are running a K&N filter or other free flowing unit than the stock one then you could also be leaning out your air/fuel mix. I experienced popping on decel with my ZRX1200 when it was set up stock on air intake and exhaust especially when I switched to a K&N air filter. Once I rejetted and added an aftermarket exhaust the popping on decel went away. I ran a richer mix then even though I opened up the air intake and had a freer flowing exhaust.
Being a bit lean on deceleration may actually be better than running rich all the time. Mama Kaw has made them so since getting into 4 strokes over 4 decades ago ever since the EPA stuck their nose into things.
Last edit: 24 Sep 2013 17:21 by Forrest.
- dkoz
24 Sep 2013 17:20
yes the 1000 is stock it is the stock jetting and the stock exhaust stock air box ..has an ever slight leak where the header pipes meet the mufflers.I can't seam to seal them 100%
Attachment IMG_20130921_151020_425.jpg not found
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
1978 Z1R D1
1978 A2
- Forrest
- The Mad Duck
24 Sep 2013 17:25 - 24 Sep 2013 17:27dkoz wrote: yes the 1000 is stock it is the stock jetting and the stock exhaust stock air box ..has an ever slight leak where the header pipes meet the mufflers.I can't seam to seal them 100%
Beautiful Bike you got there!
The leaks at the header to the mufflers on many stock exhausts is normal and Should Not Be Blocked. They help drain moisture from the exhaust system thus preventing corrosion and premature rusting out. Kawasaki got this right. How many original Honda CB750 and CB500/550 exhaust/mufflers do you still see out there. The Honda units did not vent and those pretty chrome exhausts were always rusting out. My KZ650 has the stock pipes and the exhausts have small holes at the header to the mufflers to vent the system. Yours may well have this too. I would not block them if this is the case.
Last edit: 24 Sep 2013 17:27 by Forrest.
- MDawnz1
24 Sep 2013 21:01
Sounds like an air leak at the top of the exhaust system.
When you close the throttle it PULLS in fresh air from the leak.
Now you have more air to mix with any very hot unburned fuel in the pipes and POP.
1974 Z1a, still 903
- testarossa
24 Sep 2013 23:15dkoz wrote: yes the 1000 is stock it is the stock jetting and the stock exhaust stock air box ..has an ever slight leak where the header pipes meet the mufflers.I can't seam to seal them 100%
I just wanted to say that's a damn fine looking bike.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- dkoz
25 Sep 2013 12:37
thanks shes my favorite one..its been a few years sense ive had to fine tune anything..this is a wonderful site...has been very helpful..
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
1978 Z1R D1
1978 A2
