not going in second gear
  • deanbyron
  • deanbyron's Avatar Topic Author
24 Sep 2013 09:12
#607561
Hi there. I have striped my engin and put in a new crank. Now just before total assemble and fastning i want to check the gears. So it does not go into second gear. Neutral and first gear works but get stuck going over to second. So check the extra gears asembly and does the same.
Any body can help. Or have i screwed up two gear assemblies?
Thanks
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: not going in second gear
24 Sep 2013 09:22
#607564
I'm not really sure what you're working on but most older Kaw's have a "positive neutral finder." You won't be able to shift into second until the output shaft is turning a certain speed.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
24 Sep 2013 09:32
#607566
If your bike is newer than 1977 it is normal. Beginning in 1978 a "feature" was built in using 3 little balls in the output shaft to prevent upshifting if the bike was not moving. Ed
  • deanbyron
24 Sep 2013 11:09
#607578
Thank you for all your help. Its a 1981 gpz1100
  • baldy110
  • baldy110's Avatar
24 Sep 2013 14:12
#607600
Spin the output shaft while shifting gears, it should work then.
  • zed1015
  • zed1015's Avatar
  • Away
24 Sep 2013 19:19 - 24 Sep 2013 19:21
#607628
650ed wrote: If your bike is newer than 1977 it is normal. Beginning in 1978 a "feature" was built in using 3 little balls in the output shaft to prevent upshifting if the bike was not moving. Ed
The kz900/1000/1100 etc had the second gear lockout bearings fitted from the beginning in 1972.
You need to spin the output shaft fast enough for the bearings to move out under centrifugal force whilst operating the gear lever.
You should then be able to select second, then on to 3, 4 and 5 without spinning the box.
Last edit: 24 Sep 2013 19:21 by zed1015.
24 Sep 2013 19:28 - 24 Sep 2013 19:28
#607629
Interesting! I thought they all got it at the same time as the KZ650 (1978). Thanks for the correction. Ed
Last edit: 24 Sep 2013 19:28 by 650ed.
