Gasket question for case Kz1000m
  • lucienmaier
  • lucienmaier's Avatar Topic Author
23 Sep 2013 13:05
#607438
So I am putting my case together this weekend. Opened my gasket kit and could not find the gasket for the split crankcase. (Some words were said)
then I look this morning and I can not find that gasket on any parts list? (More words)
does that sucker not use a gasket? or can someone shoot me a link to what I am looking for?
Anyone!?>>>>
--1981 Kz1000m CSR--
--Converted to 1100CC---
  • martin_csr
  • martin_csr's Avatar
Re: Gasket question for case Kz1000m
23 Sep 2013 13:17
#607439
You're probably supposed to use a liquid gasket. The bottom end section of the manual should have guidance on how to proceed.
  • lucienmaier
23 Sep 2013 13:22
#607441
That is what I am coming to and I have the clymer at home so I will take a look later
but if anyone know for sure let me know?
  • OnkelB
  • OnkelB's Avatar
23 Sep 2013 13:39 - 23 Sep 2013 13:45
#607444
As Martin says you're supposed to use a liquid gasket - this is what you need:
ThreeBond 1194
Also very useful for the cam end plugs, just a thin coat on the mating surface of the plugs.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 23 Sep 2013 13:45 by OnkelB.
  • MDawnz1
  • MDawnz1's Avatar
24 Sep 2013 14:59
#607604
OnkelB wrote: As Martin says you're supposed to use a liquid gasket - this is what you need:
ThreeBond 1194
Yup, that's the right stuff to use.
Don't even think about anything with silicone in it!!!!!!
Mike
1974 Z1a, still 903
