Valve oil seals removal.
- pbmax
21 Sep 2013 23:39
79 kz750 twin
I have the valves out and cleaned , but I'm wondering about the oil seals. How do I know if they need to be replaced? Whats the best way to remove the valve stem oil seals? I tried a pliers but it felt like the seals were going to get trashed that way.
Thanks!
Thanks!
- Motor Head
Re: Valve oil seals removal.
22 Sep 2013 00:12
You won't be able to remove them without damage. These should be replaced, as they come in a top end gasket kit. Removing them with the proper stem seal pliers is easiest, but you can use needle nose pliers, or even a pick.
- bountyhunter
22 Sep 2013 01:52 - 22 Sep 2013 01:56
No eBay APP ID and/or Cert ID defined in Kunena configurationThey are the first things that go bad. Replace them with VITON seals. I have seen them on ebay for $15.
Last edit: 22 Sep 2013 01:56 by bountyhunter.
- bountyhunter
22 Sep 2013 01:53They did not come in mine which was the Athena kit. They do sell them on ebay.Motor Head wrote: You won't be able to remove them without damage. These should be replaced, as they come in a top end gasket kit.
- pbmax
22 Sep 2013 11:49
I'll replace them then.
Do the new ones simply get pushed onto the valve guide??
- turboking
22 Sep 2013 11:56pbmax wrote: I'll replace them then.
YES..... :S
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- pbmax
23 Sep 2013 16:19
The reason I ask is because the manual says to "replace the seal's clip".
- Cynjut
23 Sep 2013 17:40
If you put the old seals back in, you run the risk of having one of them fail sooner than needed. While you have the valves out, just replace the seals. Just use the pliers and yank them out. The old ones are held on by a spring circle and should be kind of hard to remove. The new ones will 'pop' into place and you'll have the confidence of having new oil seals.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
The following user(s) said Thank You: pbmax
